Old 06-01-2012, 02:08 PM   #1
crazycal's Avatar
Fuel MPG with DT466 and AT545???
What kind of mileage should I expect with a 466/545 combo in a flat front. I don't have the exact length. About 11 window. Not sure about the rear end. I know I can't get exact but a high and low would be nice.
I'm hungry!
You Gotta Let Me Fly
Old 06-07-2012, 08:05 PM   #2
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Fuel MPG with DT466 and AT545???
What is your engine speed at 60MPH?
Anything with a 545, unfortunately, will use more fuel than the same vehicle with a lockup transmission.
Jarlaxle
Old 06-08-2012, 12:33 AM   #3
crazycal's Avatar
Not sure about that. I haven't driven it yet. Probably about two weeks is when I will pick it up.
I'm hungry!
Old 06-11-2012, 11:50 AM   #4
Chassis: Genesis
Engine: Cornbinder 466
Rated Cap: 71
I have a 1995 Genesis with that combo and it gets an honest 10 MPG.
Newfiedogs is offline   Reply With Quote
Old 06-11-2012, 12:12 PM   #5
crazycal's Avatar
Nooooo! Say it isn't so. That's awesome. Some told me 8, then 7, then 6.5. I stopped asking because it just kept getting lower.
I'm hungry!
Old 06-14-2012, 01:32 PM   #6
Chassis: Genesis
Rated Cap: 71
Just leave the pump alone unless it needs work. Most lower numbers are from those that have done something to theirs to get more power and speed...why, these things are huge, heavy and just fun to drive. They don't stop like a Vett so don't expect them to be a Vett.
Once you start driving yours you will appreciate the fact that it is just friggin cool to drive a skoolie.
Tracy
Old 06-14-2012, 05:32 PM   #7
Chassis: Genesis
Engine: Dt40
I have a 1993 Amtran Genesis with the same combo and I actually think it does a little better than 10mpg. I have been amazed.
bhays is offline   Reply With Quote
Old 06-14-2012, 05:48 PM   #8
GreyEagle's Avatar
A lot of that 10 will depend on da foot!!!!!!!!!
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 06-15-2012, 11:03 AM   #9
Diesel Dan's Avatar
Engine: DT466/AT545
I'm getting closer to 8mpg on mine doing 60-65 mph on flat highway with maybe some rolling hills here and there. I don't remember the ratio on my gear box but I am doing about 2800 rpm at 65mph.
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-15-2012, 11:07 AM   #10
crazycal's Avatar
If you were driving 55, what would your rpms be and do you think you mileage would be much better?
I'm hungry!
1995 DT466 Fuel line gildorr Mechanical and Drivetrains 5 06-30-2014 10:09 AM
AT545 overfull! bus-bro Mechanical and Drivetrains 2 07-27-2010 11:03 AM
at545 transmission The Wanderer Classifieds | Buy, Sell, Swap 15 05-24-2007 12:13 AM
Does a MT643 fit instead of a AT545 ????? Protecx Conversion General Discussions 1 02-09-2007 09:14 PM
I need a Used or Rebuilt Transmission (AT545) ParadigmCrime Everything Else | General Skoolie Discussions 6 09-10-2006 10:04 AM
