Old 07-09-2019, 02:05 PM   #1
Rogue1bus's Avatar
Gauge cluster plug repair
My 2002 Amtran RE t444e gauge cluster cuts on and off while driving etc.
I re-soldered all the points on the cluster circuit board, some of which were bad. But I’m pretty sure the plug is bad because I can reach under the cluster while driving and push the plug and the gauges will turn back on.
Does anyone have a source for the plugs? I’m considering just cutting the old plugs and rewiring it to a replacement plug if I can source them. IMG_5770.jpg
Or can I repair the existing plugs with some like the tools pictured below?
Thanks!
Rogue1bus is offline   Reply With Quote
Old 07-09-2019, 02:13 PM   #2
try cleaning the terminals on the cluster and on the harness with electronics cleaner.. mine acted the same as yours.. touch the wires and it comes back.. once I redid all my solder joints it worked good for about 2 years.. now its breaking again.. the 2 wires that are the culprit are the black twisted pair which is the Data-link between the ECM and the cluster.. so it causes the 5 main gauges to freeze.. (MPH,RPM,OIL,VOLT,TEMP)
Old 07-12-2019, 02:46 PM   #3
Rogue1bus's Avatar
Right on. I cleaned the plugs and used a scribe to bend the ends of the connectors on the two black twisted wires. Basically I smooshed them alittle to create a tighter connection on the board prongs. We’ll if it works...
