Originally Posted by busbuild
I'm guessing your bus is in the 2003-2005 range? This is right around when they started pulling the lead out of solder to make things RoHS compliant. Places didn't really figure out how to wave solder with lead free solder for a little while. I'd definitely check those solder connections though. That is my inexperienced $0.02. Good luck!
Great advice, thank you.
Update:
I pulled the cluster last night and resoldered (melted and added a small amount of new modern solder) all the connections on the back.
Everything seems to be working great except the WTS (Wait To Start) light still isn’t illuminating. The fuel gauge came back to life and started working so now I have two fuel gauges 🤣 the factory one and the aftermarket replacement.
I’m pretty current the glow plugs are working fine since it’s 50 degrees F outside and the engine starts instantly. So I have to figure out why the WTS light isn’t coming on... maybe the bulb or the housing. I suppose it should be pretty easy to trace out the connections leading to it and double check them too..
