Old 10-21-2018, 04:02 PM   #1
Rogue1bus's Avatar
Gauge cluster problemS
Iíve been experiencing terrible problems with my gauge cluster, itís intermittent on and off especially on the plug on the right side. My air alarm goes off randomly, my wait to start light no long illuminates etc.
Iím pretty sure the actual cluster is fine (except the fuel gauge which I replaced with and aftermarket one) it appears there is a fault in the plugs or wires near the plugs. If I reach under the dash and move the wires or the cluster while itís in use the light on the air gauge cuts in and out and the gauges act erratically.
Any idea how I could fix this or rebuild the cluster wiring?
Rogue1bus is offline   Reply With Quote
Old 10-21-2018, 04:51 PM   #2
Chassis: International FE
Rated Cap: 84 passengers
There are companies that will rebuild the gauge clusters on these buses/trucks. Just do some internet searching and you'll come across one.
rensch26 is offline   Reply With Quote
Old 10-21-2018, 05:28 PM   #3
Chassis: IH
The IH gauges are notorious for this. The connections can be re-soldered if you are handy with it.
Old 10-21-2018, 06:04 PM   #4
Rogue1bus's Avatar
I think itís the actual plug, so you mean resolder the wires into the plug?
Old 10-21-2018, 06:06 PM   #5
Rogue1bus's Avatar
Or the board where the female side is?
Old 10-21-2018, 08:40 PM   #6
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
Or maybe rebuild the entire gauge panel with good-quality separate gauges, such as those by Speedhut or VDO. We even have an International truck at work, and guess what, its gauges are all toast! If you build your own gauge panel you can choose what's important for you, and have a comprehensive display of everything that matters.
Old 10-21-2018, 09:02 PM   #7
Rogue1bus's Avatar
The problem with that is the engine lights, wts light, alarms etc wonít work... but I like where your thought process is
Old 10-25-2018, 01:09 PM   #8
I'm guessing your bus is in the 2003-2005 range? This is right around when they started pulling the lead out of solder to make things RoHS compliant. Places didn't really figure out how to wave solder with lead free solder for a little while. I'd definitely check those solder connections though. That is my inexperienced $0.02. Good luck!
busbuild is offline   Reply With Quote
Old 10-26-2018, 06:26 AM   #9
Rogue1bus's Avatar
Great advice, thank you.
Update:
I pulled the cluster last night and resoldered (melted and added a small amount of new modern solder) all the connections on the back.
Everything seems to be working great except the WTS (Wait To Start) light still isnít illuminating. The fuel gauge came back to life and started working so now I have two fuel gauges 🤣 the factory one and the aftermarket replacement.
Iím pretty current the glow plugs are working fine since itís 50 degrees F outside and the engine starts instantly. So I have to figure out why the WTS light isnít coming on... maybe the bulb or the housing. I suppose it should be pretty easy to trace out the connections leading to it and double check them too..
Old 11-02-2018, 04:36 PM   #10
Year: 91
Chassis: 3860
Engine: Dt360
Rated Cap: 44
On my 91 it is the wires going to my gauges.
Old Bones is offline   Reply With Quote
