Old 06-02-2019, 10:23 PM   #1
CMORGANSKOOL's Avatar
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
Heater wires
Rear heater. I traced these back to the switch but I’m still confused. Low/High. Two white and one red. Are all 3 + ?
CMORGANSKOOL is offline   Reply With Quote
Old 06-03-2019, 05:42 AM   #2
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Shoukd be low,high,ground
Doe69936 is offline   Reply With Quote
Old 06-03-2019, 06:13 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Test them with a digital multimeter. Meter black to ground, red to each wire while switching with the switch. It will tell you which is +. Also check different combinations of wire to wire.
Or just look at a wiring diagram.
Old 06-03-2019, 09:27 AM   #4
Coachwork: IC
Chassis: FE Bus
I was going to test them but I didn’t bring the ignition key. Just hoping someone has repurposed one of these. I want to repurpose the switch for my water pump and wire it in to the solar.
Old 06-03-2019, 09:56 AM   #5
brokedown's Avatar
Mine grounded to chassis and only had two wires, low + and high +. Not a lot of other things to do in a heater box.
