Old 10-31-2011, 11:16 AM   #1
Help - international 3800 - will not turn over
Hi - I need help here. i have a 1998 thomas bus wih an international 3800 series chassis. the bus was idling and then just stopped dead. now when i go to start it - when i turn on the ignition, the light go on except for the WAIT TO START - that doesn't go on and the motor will not crank over - i've check the normal fuses - but cannot fiture it out - is there another safety override or something i am missing? thanks in advance for you help!
THanks
brent is offline   Reply With Quote
Old 11-06-2011, 04:29 AM   #2
Jive Turkey's Avatar
Re: Help - international 3800 - will not turn over
You need to give more and better information. What engine/trans is in your bus? Do you think the engine is locked up mechanically or does it seem to be an electrical problem. What checks have you made so far?
The better information you give the better the chances are to solving your problem.
Jive Turkey is offline   Reply With Quote
Old 11-06-2011, 08:56 AM   #3
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
you can always check the starter out first, just to make sure it isnt locked up, cross out the solenoid with a screwdriver, justa suggestion
see my conversion at http://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 11-06-2011, 04:00 PM   #4
A very dangerous and potentially deadly one using the method you described.
Old 11-20-2011, 04:45 PM   #5
Coachwork: Ward Genesis
Engine: DT466/MT643
A 1998 with a WTS light means it's almost certainly a T444E...my first thought is that you blew a fuse/melted a fisible link someplace.
Jarlaxle
Old 04-15-2012, 03:46 PM   #6
Engine: DT466/MT643
Originally Posted by jones1
I have a 1999 bluebird international 3800 T444E school bus I can run for two week and then my engine just get hot and shuts down I wait 10 min. It cools off then it cranks back up I change fuel pump,relays, ICP sensor,the Exhaust back Pressure sensor it still do the same thing what could it be.
Is it actually overheating? If so, check the water pump.
Jarlaxle
Mountain Laurel - 1991 International 3800 DIYchaos Skoolie Conversion Projects 14 11-26-2016 04:10 PM
96 International 3800 sickrunvanyardsale Skoolie Conversion Projects 20 07-01-2016 03:22 PM
1996 International 3800 Amtran jackson7209 Classifieds | Buy, Sell, Swap 0 10-15-2013 09:09 AM
Tourtech Bus - 1997 International 3800 TourTech Skoolie Conversion Projects 22 05-26-2013 03:08 PM
1990 3800 International hoeftfamilyrules Classifieds | Buy, Sell, Swap 0 09-22-2008 09:13 PM
