Old 04-22-2019, 02:10 PM   #1
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Chassis: IC FE 9 Window
Rated Cap: 29850
How much stuff to remove to replace my fan clutch?
Hi All,
It looks to me like I will have to remove all of the cooling goodies from the grill back on my 2006 FE300 to replace my free spinning fan clutch.
1) Are there any published step by step instructions on how to get access?
2) While I am in there are there other things i should replace (idler pullys etc) [114K miles]...
I am clearly living the down side of an FE...
PeteinSF is offline   Reply With Quote
Old 04-24-2019, 03:16 PM   #2
WARGEAR's Avatar
Coachwork: AmTran/Wolfington
Engine: International DT466E 190HP variant
Rated Cap: 72 pax 29500 GVWR
I’d check each pulley for any wobble/play, cracks, mounting bolt torque, and replace the belt(s). Clean out the rad from leaves or crud, check the fan itself for lose parts or dings/bends, and change any hoses if they look cracked/frayed or feel spongy.
WARGEAR is offline   Reply With Quote
Old 04-24-2019, 03:29 PM   #3
I had to change out a compressor on a 87 BBAA. Had it completely disassembled except for one 1/2" bolt in the front of the bracket that required pulling the whole front of the bus out including the radiator. About an hour of labor for 3 seconds to remove the bolt.
Old 04-24-2019, 07:03 PM   #4
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
I believe fe is the nomenclature for front engine . I replaced the radiator in my international 3800 not long ago pretty strait forward removal of the front doesn't take long just need some help pulling the hood kinda awkward for one person
Doe69936 is offline   Reply With Quote
Old 06-18-2019, 08:06 PM   #5
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Rated Cap: 29850
HUGE fan clutch in hand.
It looks like I am going to have to pull the front of the bus off to get the radiator and shroud out of the way.
Does any one have a picture of the removal of an IC flat nose radiator and CAC?
I am assuming I am unbolting supports and bumper from the frame rails and rolling it forward...
Old 02-26-2020, 11:30 AM   #6
PeteinSF's Avatar
Year: 2006
Coachwork: IC
Rated Cap: 29850
Pictures of the swap
Hi All,
Here are some pictures of the fan clutch swap.
As a note if you have a split cooler system (CAC on top, radiator on the bottom) you must set the thermostat all the way counter clockwise or the fan will not start until 210-220+.
I learned the hard way adjusting this after the radiator is installed is almost impossible to perform.
I think the cooler air through the Inter-cooler (CAC) keeps the clutch housing much cooler then a back to back setup and prevents a normal engagement of the fan with the factory setting.
With the setting at minimum it kicks in just below 210 and shuts off about 180-185.
IMG_2555.jpg   58553570457__0CC4870D-EEBB-4174-A786-BD9557A8C6BE.jpg   58554663448__139FAE92-E9E0-4ACC-888D-3B592ADA12A9.jpg   58560306684__7AB684DC-965F-416F-8AD6-D1F7E5E3003D.jpg   58560345253__87FA76F5-0185-4C09-BE22-A5BE7FCCDD0B.jpg
Old 02-26-2020, 01:14 PM   #7
Christopher has a method for adjusting them without pulling anything. He made a a video.
Love to see maintenance updates on buses! Cooling systems are no joke.
