Old 11-02-2015, 06:12 PM   #1
Coachwork: AmTran/Gensis
Identifying Transmission Model?
I'm thinking about buying a 1997 - 72 passenger International-Genesis with a mechanical DT466, but I can't for the life of me find the model of the tranny to confirm it's a MT643 or newer? I crawled under and looked on the passenger side for the metal tag and no luck. I called the mechanic at the bus shop, and he said he believes it was a 3000 series Allison. I can't help but doubt that on a 1997? Any ideas?
jontettleton is offline   Reply With Quote
Old 11-02-2015, 07:00 PM   #2
2kool4skool's Avatar
Here's a 643
Don, Mary and Spooky the cat.
Old 11-02-2015, 08:21 PM   #3
http://www.skoolie.net/forums/f33/ho...pecs-1641.html
Old 11-02-2015, 09:33 PM   #4
FWIW, our 545 has a temp sender on the pan but it sits higher.
Old 11-03-2015, 12:44 AM   #5
Engine: 190hp 5.9 Cummins
The 3000 series Alison transmissions are the best of the available transmissions in school buses. Most common variant is the MD 3060 double over drive, 6 speed automatic transmission.
If it has a electronic shift panel, it's got a 3000 series or better transmission.
Not all 3000 series transmissions have the electronic shift panel, but most will.
This is what you want to see.
Old 11-14-2015, 11:05 PM   #6
Thanks much for you help!
identifying, tranny, transmission
