I was looking for threads regarding the thermostat and t-stat housing when i found this thread. I know it's an old thread and most of the guys who have posted here probably have come to a solution they can live with.
When we bought our bus in July of 2019 and ran it the 300 or so miles home from Phoenix to Freedom Field, NM it was hot. It was never below 105F all the way home. I recall as long as I ran it at 55MPH or less we had no overheat problems. when climbing the many hills on the way home we mostly downshifted into 3rd and crept along at about 2000rpm.
After we arrived home we found that we could run 65MPH between our place and Las Cruces and never get a warn. On the way home the steep hill on 10 going west out of Las Cruces would always get us down to about 30 MPH if we wanted to avoid the heat warning.
Then in November of 2019 we had a deep freeze. This is when we realized we hadn't ever tested the specific gravity of the coolant. Admittedly it was unlikely that there was any antifreeze in the water. The radiator split a seam.
I attempted to silver solder the seam. Then I took it to a radiator shop to see if they could save me. They dipped it and pressure tested it. The prognosis was it was too rotten to fix. They suggested I call Navistar for the price on a new one.
Well $1640.00 was a lot more than I wanted to spend. I found this radiator on ebay for much less and took a chance.
https://www.ebay.com/itm/25445144149....c100148.m2813
Three rows of core rather than the two the stock radiator has and about $500.00. I think it is even cheaper now.
The only trouble I had with the install was that the lower outlet was a different size than my original.
The results were amazing. I was only looking to replace the bad radiator and not really trying to boost performance but the end result was a much cooler running engine on hot days and the ability to head west out of Las Cruces up the big hill at 55 in 4th gear.
Thought it might be a help to anyone who might be needing a new radiator for their t444E or powerstroke engine.
