Old 09-22-2015, 02:51 PM   #1
Coachwork: International 3800
input needed
bought a 97 international with a Navistar T444E and Allison auto trans. any input or knowledge would be great. I have the service records from the school . no major problems in 191000. just maintence, tires and brakes . ideas on easy parts to stock or quirks they might have. Thanks
efgjr is offline   Reply With Quote
Old 09-22-2015, 02:55 PM   #2
Did it come with the optional Rolling Coal Paackage?
Old 09-22-2015, 02:57 PM   #3
not sure I follow but im glad your enjoying yourself
Old 09-22-2015, 03:11 PM   #4
Nothing to follow, I'm just bored.
Welcome to the forum!
Old 09-22-2015, 03:19 PM   #5
same here, I fig it doesn't make much sense to make roof uber thermal when the entire bus is skirted in single pane glass. ive got a new trailer with xtra roof ins package and still gotta park under a tree in summer and search for sunlight in winter. besides taking seats out. just trying to pinpoint a place to start.
Old 09-22-2015, 03:53 PM   #6
Are you leaving the metal paneling inside?
I'd still insulate it as everything will work more efficiently that way.
THe new paneling you put in after that would feel much cozier than metal too.
Then there is a certain appeal in just leaving it "a bus" and using it as a rought camper/utility rig.
The floor is a good place to start either way.
Old 09-22-2015, 04:43 PM   #7
juliol's Avatar
Engine: 3208 turbo Cat
I know is a pain to remove the ceiling panels, but is worth it. I would start by removing the ceiling before the floor, that way you don't destroy the new floor while doing the ceiling.
Hey Eastcoast, by removing the ceiling will the structure of the bus loose strength?
J
juliol is offline   Reply With Quote
Old 09-22-2015, 04:46 PM   #8
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Pulling the interior panels affects the structural integrity not a whit. And pulling the panels down are easy- just unscrew, no rivets to deal with.
Also pull your side panels, and get rid of that insulation as well, plus it'll be easier to seal where the stop signs were mounted
Captain Obvious on deviantArt
Old 09-22-2015, 05:05 PM   #9
I def plan on adding insulation to floor and sides. Leaving ceiling panels in and adding to it. This bus is rust free no leaks in top. But do plan on coating too on outside as well.
Old 09-22-2015, 08:37 PM   #10
J
No, not by any appreciable amount.
