Old 06-16-2016, 09:04 AM   #21
Chassis: International 1753
Engine: 6.9 International
Originally Posted by spgrogers View Post
I have a 2002 International 7.3 and the Governor was preset at 55mph from when it was a school bus. Do you know how to disconnect, or turn it off or is it set up in the computer? I would appreciate any advice.Thanks
If your rear gearing and transmission are set up correctly, meaning that you're capable of going faster without redlining it, then the speed limiter is in the computer and should be easily changed by somebody with servicemaxx.
Old 06-16-2016, 09:46 AM   #22
Coachwork: International T444E
Thats kind of what I thought. Yes the bus will defiantly do faster than 55 its just set not to go any faster it will always do exactly 55 and thats top speed with no redlining. I just didn't know how international did its diagnostics or communication with the computer systems, so its a ServiceMaxx? Thanks
spgrogers is offline   Reply With Quote
Old 06-16-2016, 01:23 PM   #23
Chassis: International S3800
I wish I could find a darn fan clutch for my 91 internarional DT360... all my service manuals mention air fan clutches.. nothing mentions a viscous thermal clutch.. yet I have 1.. and i saw an 1989 Bus with one just like mine...
I supposed the OP is long gone now!.. but I need to get my fan spinning faster and correctly..
Old 06-16-2016, 02:28 PM   #24
Servicemaxx is the program. Requires a subscription and a laptop with some sort of adapter. There are other service tools out there, such as the nexiq prolink that might be capable, but I'm not sure on that.
Old 06-16-2016, 02:30 PM   #25
OP is long gone. You'll see that on forums like this where you'll have an expert show up for a short while and get bored then never come again.
It'd be nice if people would stop posting in here and start up a new thread regarding their problem.
Old 06-16-2016, 09:18 PM   #26
So far my only issue has been the Governor. Just bought it a couple months ago and have not been able to put much road time on it yet. Im sure I'm going have a few more issues pop up.
Old 07-01-2016, 07:22 PM   #27
Year: 1981
Coachwork: Wayne Lifeguard
Engine: Gas. Cubic inch displacement unknown at this time
Rated Cap: 15 pax
Where do I get a "neutral safety lookout switch"?
Juneau Jimmy is offline   Reply With Quote
Old 12-28-2016, 03:28 PM   #28
Yellow_Submarine's Avatar
Hi! I have a 1999 international with a dt444e engine. It has an Allison transmission. I have a trans leak and I've pinpointed the location. I've never messed with a trans but the spot the leak is at looks pretty easy. I have pictures of that helps. It's leaking from a small plate on the lowest part of the trans. It's right where the trans and flywheel meet up but at the bottom of the housing. The plate has two small hex bolts. How do I post pictures?
Yellow_Submarine is offline   Reply With Quote
Old 12-28-2016, 04:29 PM   #29
Chassis: IH
Don't know how active this thread is, but ...
'87 IH with 9.0L engine and Allison Auto (not sure of model; I believe it was converted from a manual). Backup lights inoperative (have not done extensive diagnostic on them yet).
Dash was "dark"; removed it to replace bulbs. Some of which light up now (all did prior to re-installation). The dash has the flimsy Mylar printed circuit sheet ... and the voltage gauge stopped working after the re-install...
I also have the mechanical speedometer. If I redo the gauge cluster, I would like to convert it to an electronic version.
Old 12-28-2016, 05:03 PM   #30
Submarine, that is just an inspection plate for the torque converter. If you have fluid coming out of there it is either the front seal, torque converter bushing is worn, or the pump to case gasket is leaking. All of which require removal of the trans.
Swift,
Not really sure what you're asking.
Ignition cut-off problems CostelloCrew Conversion General Discussions 4 11-06-2014 07:00 AM
Keep the bus? Or too many problems? MonsieurBon Conversion General Discussions 18 07-10-2010 11:32 AM
Problems problems oh what fun they are dragonfly112 Conversion General Discussions 5 05-05-2010 11:09 PM
WVO problems? recycler Veggie Oil | WVO | Biodiesel | SVO 5 02-13-2009 12:06 PM
car problems TravelingMan Everything Else | General Skoolie Discussions 7 04-13-2005 12:51 PM
