Old 04-03-2018, 11:35 AM   #21
Easy fix for the bulge would be to just cut the last, bulging inch off the hose and reinstall it as a temporary fix before replacing the hose with one that is compatible with the fluid going through it. I would not be overly concerned about driving it as long as the gauges work and you keep an eye on fluid levels.
Old 04-03-2018, 02:15 PM   #22
Coachwork: International / IC
Chassis: IC Corporation/Blue Bird
Engine: Navistar DT466E
Rated Cap: 19 + wheelchair capacity
Originally Posted by George View Post
Keep the appointment booked
My Thursday looks light enough I could run out there at some point so we can at least have a look and see if there is something simple and check all fluids.
Remember that Alberta is a dry climate and cold , particularly this year.
Many times people bring cars up here that seem to bleed to death and it’s usually due to a shrinkage problem of seals. Add in synthetic fluids and you can have a full crap your pants situation.
Where are you around here?
I'm hanging out in Cluny. House sitting for a family on holiday out of the country.
I can't tell you how much I appreciate this.
If you can't for any reason, I totally understand.
Michael
mrmchoohaa is offline   Reply With Quote
Old 04-03-2018, 02:18 PM   #23
Originally Posted by Jdawgsfanasty View Post
I'm in Houston...not much help...sorry
Sorry about that! Getting the hang of the forum.
Old 04-03-2018, 03:06 PM   #24
Jdawgsfanasty's Avatar
All good...I'd help if I could
Jdawgsfanasty is offline   Reply With Quote
Old 04-03-2018, 06:21 PM   #25
Coachwork: Corbeil
Chassis: e350 SD
Engine: 7.3
Rated Cap: 18
Michael
I can pop over and have a look at 2:00 Thursday just to get an idea of what’s going on. If it’s something we can do there i will be able to tell and you can cancel that appointment. If it looks more serious or out of my scope of knowledge you can continue on with County Auto repairs Friday.
Plug the bus in at 10 AM
PM me directions
George is offline   Reply With Quote
Old 04-03-2018, 08:36 PM   #26
Awesome. Thanks for your help!
diesel, leak, leaks, oil, transmission
