Old 09-15-2015, 05:59 AM   #21
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
In Texas, it's .25 of an inch if I remember correctly.... As I posted earlier, ALL the buses I drive have NO play at all.
M1031A1 is offline   Reply With Quote
Old 09-15-2015, 08:09 AM   #22
wunderhut's Avatar
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
It's 10 degrees. That translates to about 2 inches on a 20 inch wheel. Any more and a big rig fails inspection, out of service! There's a reason it fails inspection; it is not safe! Your bus shares most of the same steering components as the big trucks. If it's not safe for a big truck, it's not safe for your bus either.
wunderhut is offline   Reply With Quote
Old 10-20-2015, 08:47 PM   #23
Year: 1978
Chassis: IH Loadstar 1600
Engine: 345 v8
Assuming this is way to much play... when I do that, the steering wheel doesn't move. Or does the engine need to be on, to create pressure???
Trask97140 is offline   Reply With Quote
Old 10-21-2015, 01:52 PM   #24
Chassis: International 1753
Engine: 6.9 International
I don't know if I'm reading you right, when you twist that shaft, the steering wheel doesn't move? Looks like you have a 1/4 turn of play? Either way, that amount of twist is beyond excessive and close to being dangerous. Have the gearbox gone through and try to clarify what you meant about the wheel not moving.
Old 10-21-2015, 02:17 PM   #25
Ouch! Can't recall ever seeing that much free play without the gear engaging. If the the pitman arm does not move with the shaft from the wheel, there is an enormous amount of wear/play in the gearbox itself. That definitely needs tending to. Time to replace it all most likely. Any heavy duty wrecking yards nearby?
Old 10-21-2015, 04:55 PM   #26
Year: 1978
Engine: 345 v8
That is correct, while rocking it back and forth the steering wheel does NOT move...
So new gearbox ya say?? Ill have to look around about the heavy duty wrecking yard. Im not certain. Think that would be a fairly easy find?
Thanks for the input Booyah & Tango
Old 10-21-2015, 06:28 PM   #27
You might check with some International or other truck service companies to see if there is a rebuilder in your area. Would be cheaper than all new but likely more than a used unit. There are a couple of shops here in Houston that rebuild medium to heavy duty gear boxes. If you go used, be sure to check it out as best you can. Like I said, the pitman arm should move right along with the wheel shaft. Mine is a used Isuzu but it has pretty much zero play and moves smoothly all the way from stop to stop.
Good luck with the hunt.
Old 10-21-2015, 08:45 PM   #28
Year: 1978
Engine: 345 v8
Good call! There's a local International dealer/shop called Brattain International. Heard some good things, Ill give them a buzz and see what they say. Definitely need to get this figured out ASAP. I thought it liked to walk a bit more than normal... no more driving for me. Hopefully go the rebuild route if possible.
Thanks,
Trask
Old 10-21-2015, 10:27 PM   #29
Rated Cap: 40 Prisoners
I would do your experiment with the engine running so you have hydraulic
pressure. Some of the play your experiencing could be play in the spool valve
and your play may decrease with pressure on the system. Then I would try
adjusting the gear box if the play is not to excessive when powered up. Just a
thought.
Old 10-22-2015, 10:04 AM   #30
You got major problems then. The steering wheel and shaft should move in unison, with no slop at all. Anything else shows worn u-joints in the shaft, which is worse then the play in the gear box.
Get the shaft and wheel solidly connected and then we'll figure out what to do with your gearbox.
