Old 10-30-2019, 09:06 AM   #1
Dead pirate's Avatar
Coachwork: myself
Chassis: amtran
Engine: international dt466e allison md 3060
Rated Cap: 13 ton or so says the tit
Md 3060 ecm
Can i just insert an ecm programmed for 6 gears into my rig?
Dead pirate is offline   Reply With Quote
Old 10-30-2019, 09:13 AM   #2
you need one that the tag on it matches your current configuration...
its best you can find one from another DT-466E so the shift calibration curve is built on the torque curves of that engine..
at a minimum it should be from another I-6 diesel.. RPM stamnped on TCM needs to match..
throttle needs to match
generation needs to match.. yours is in that switch year from WTEC-II TO WTEC-III .. send a picture of the data tag label from your TCM so we can see what it is..
Old 10-30-2019, 09:22 AM   #3
Coachwork: myself
Chassis: amtran
I will. I have to get back to it. Im on a trip to Virginia and back. Thanks
Old 11-10-2019, 01:37 PM   #4
Coachwork: myself
Chassis: amtran
Does this have enough of the info on it?Click image for larger version
Old 11-10-2019, 07:05 PM   #5
doesnt have the part number of the ECU itself.. but does show you that the calibration you need is for 2400 RPM and auto-detect throttle type.. (I dont know how your bus is wiored up for throttle,.. since its a 466E I can assume they have it connected to the J1939 link which is a 3 pin WeatherPak connector coming off the engine computer with a yellow,black, and green wire.. if that connector is plugged in and going off somewhere then you can use a TCM with throttle type J1939, if that connector is just capped off then navistar used a different throttle method and your new TCM will also need to be Autodetect. im not sure on a flat nose bus where that connector is. usually near the engine.. im assuming its for the bus listed in your profile as a 466E. it *looks* like you have WTEC III TCM but I can see so very little of it in the pic its hard to tell for sure..
Old 11-11-2019, 06:27 PM   #6
Coachwork: myself
Chassis: amtran
I'll get a better picture. I was hoping to not have to take it out. But......thanks again.
Old 09-26-2020, 10:25 PM   #7
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Read this.... Lots of info there but towards the end it will give you some fruit you are looking for...
i spent 2 years trying to come up with a good solution
https://www.skoolie.net/forums/f10/a...ial-21661.html
