Old 12-12-2009, 11:03 PM   #1
NewSkewlHauler's Avatar
Engine: 8.2L Detroit N/A, Allison
motor swap suggestions for 7.3L IDI
I'm looking at a bus that has the 7.3L IDI diesel. I'm assuming it's the same one as was in my 92 F-250 I had a few years ago. I didn't mind the motor in a regular cab pickup but I think I'd like a little something more in a full size bus that I intend on hauling hay and pulling a horse trailer. What motors would "easily" swap over for more power? How much life would an ATS turbo or a Banks system breathe into this thing? Would there be other motors that would make good swaps with some mods? I guess I was thinking the all the 7.3L blocks were the same...so would a T444 or a Ford Powerstroke just bolt in?
This would be a project tackled much later, but it's something on my mind. The bus is an 89 International Bluebird with air brakes and I'm assuming the AT Allison tranny.
Thanks in advance.
Ben.
NewSkewlHauler is offline   Reply With Quote
Old 12-14-2009, 06:19 PM   #2
frank-id's Avatar
7.3L IDI
Yep I have a BB bus made by Int. Theses engines are great, The Ford and Int. are the same 7.3 IDI. The engine is very reliable if services and a few changes are done. The newer engine from Ford/Int is the power stroke with some serious differences, but mostly being an engine computer. With the computer, some serious horsepower can be made. My 1990 Blue Bird bus will go down the hiway at about 70+ MPH at the maximine engine speed. My rear gears are 4:10 but I just bought a new set of 3:73 to increase road speed but cruise at a lower engine speed. Rear gears are a compromise between top speed or climbing hills without down shifting. There are lots of Ford/Int. diesels available. Frank in Idaho
Old 02-22-2010, 03:48 PM   #3
frank-id's Avatar
7.3L IDI
There are several 7.3 engines. First there was the 6.9 that became the 7.3. The early 7.3 is known as the IDI engine till about 1992. The next series is called the powerstroke. There are many engine changes. The IDI engines did not have a computer for the engine but had a computer for the trans an E4OD.
The factory trans are junk. An overhaul is expensive. The big buses began using a computer about 1995.
My BB bus has 540 rear gears and I got some 373 gears to install. Here in Idaho it is too cold for outside heavy work. An IDI 7.3 engine is a good worker engine.
A turbo is about 30% more work and power. Do not leave home without one. All the parts from a pickup will work on a BB/Int bus... Frank
Old 04-24-2010, 06:07 AM   #4
lapeer20m's Avatar
Re: motor swap suggestions for 7.3L IDI
my suggestion is rather than swap the engine, is find a bus with a better engine already in it.
We saw two really nice rear engine cummings 5.9 mt643 buses go for under $2k each at auction.
motor swap autoqual Ford Drivetrain 1 08-28-2014 05:21 PM
gm 366 threw a rod. need to replace the motor. suggestions? azratrod Conversion General Discussions 23 10-01-2011 09:28 PM
1st Skoolie!! Suggestions welcome!! cronk3420 Short-Bus Conversion Projects 21 02-25-2011 12:26 AM
suggestions on my engine swap? kyletheyeti International | Navistar Drivetrain 5 02-17-2011 11:22 PM
Motor and trans info on a 1979 ford gas motor auto trans highvoltage21733 Conversion General Discussions 3 10-28-2005 09:31 AM
