Old 10-27-2008, 06:19 PM   #1
odyssess's Avatar
Engine: T444E 3800
My Bus suddenly won't turn over...Any Ideas???
My batteries are good, but the other day I went to start the bus and it just clicked once and didn't turn over. When I turn the key I hear a single click coming from under my switch panel on the lower left side(kinda where the heater is) If this were my car I would think the starter was bad. I haven't had a single problem in the past starting it and all of a sudden it won't start. Any suggestions as to what to check first? It's an International T444E 3800 automatic. Thanks for any help.
http://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 10-27-2008, 08:05 PM   #2
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: My Bus suddenly won't turn over...Any Ideas???
i would check and see if all the lights come on-if they dont id check where the ground connects to the engine then i think i would try to short out the solenoid and see if the starter turns it over if it turns over id check for safety switch problems such as clutch pedal switch,neutral switch etc. sounds like a connection somewhere to me. i hate it when this **** happens timbuk
Old 10-28-2008, 11:57 AM   #3
odyssess's Avatar
Engine: T444E 3800
Can't seem to find any loose wires. The engine warn light stays on when I try to start it. I'm still messing with a few things, but so far no luck.
Keep on Keeping on.
Old 10-30-2008, 09:45 PM   #4
the_experience03's Avatar
Where is the starter solenoid/relay mounted on this particular bus? Is it mounted right on the starter itself or is it remotely mounted? In either case there is a little diagnosis needed so the problem can be narrowed down. Now I would vote that this is a control side issue (ignition switch, solenoid, some sort of interrupt, etc), but we need to know for sure.
I'm hoping you have a multimeter. Use the multimeter and make sure you have 12 volts on the large battery cable coming from the battery to feed the solenoid. This will eliminate the power feed as a problem. Then, have someone turn the key and check to see that the "S" terminal on the solenoid (this will be the smaller control wire). Chances are you won't, but if you do then the solenoid becomes suspect (or possibly a whole starter). You probably will not which means it is time to trace wires. I wish it were as simple as just getting a wiring diagram, but it isn't. Verify that you have 12 volts feeding into the ignition switch. If you do not you might have an interrupt device in the circuit or a broken wire, etc before that. If you do not have power then I would run a 12 volt jumper wire to that power feed and see if the bus starts.
If you do have power to the switch then it is is time to dig deeper. Clearly there is something in the middle between the switch and the starter. Let me know when you figure it out.
One other thing. Don't take this the wrong way...I'm a mechanical person and got absolutely burnt by this before. Is the transmission in neutral or did someone maybe bump it into gear? This would explain the no crank (neutral safety switch) as well as the engine warn light.
Old 11-10-2008, 04:41 PM   #5
odyssess's Avatar
Engine: T444E 3800
Damn Batteries...I thought they were fully charged, but I must have had a couple of bad cells. The batteries that came with the bus were Kirkland (100 month guarantee)...so I returned them to Costco...after a little hassle they prorated them for 50%(without a receipt!!!) of the current price..so I got a free one and bought another. Now I have better stronger batteries and it turned over fast and strong. While I had them out I deceided to add in my Isolator to the mix. Now my altinator recharges my starter batteries and my aux batteries and my aux batteries won't drain my starters. I'm Happy!!! Thanks for all the help, I should have started with the easy stuff first...live and hopefully learn.
Keep on Keeping on.
Old 04-10-2010, 10:45 PM   #6
Coachwork: International Harvester
Chassis: Carpenter
Engine: 7.3L Diesel
i am having the same problem..and i know its not my batteries as i tried jumping the bus with my truck... the battery was low-ish at 12.5v the bus has been sitting a bit... i need to try testing voltage at the solenoid... there was two chewed wires thanks to a rat coming off of the transmission...fixed them... i was hoping that was the problem...but no,....hope to get assistance soon as it takes two people to test farther....(turn key and test voltage)
moliskaIH is offline   Reply With Quote
Trying to turn off heater... timmygyu Short-Bus Conversion Projects 6 08-04-2011 07:01 PM
brake & turn lights chris white Conversion Tutorials and How-to's 13 06-22-2011 10:42 PM
ENG turn up HELP keith Cummins Drivetrain 14 02-20-2010 09:59 PM
Help Fixing Turn Signals BuckBus Conversion Tutorials and How-to's 1 07-24-2008 08:54 PM
How to turn a bus into a limo Please help me! wannabapartybus Titles, Insurance, Registration and Money Matters 7 02-25-2008 09:13 PM
