01-29-2018, 08:22 PM
Rated Cap: 34
Need some help with differential math
So.....I've decided to swap my differential gearing....it's currently a 4.78
Engine is DT466E, 175HP@2300rpm, 430ft-lbs@1500 rpm (had the road speed limiter removed Friday).
Will be putting 11Rs (41") on the rears.
My Spicer ES43-5D 5 speed manual ratios are as follows....1st 7.25, 2nd 3.98, 3rd 2.23, 4th 1.29, 5th 1.00
1st and 2nd are next to worthless.....I can only roll about 10 feet in first b/4 having to shift, and 2nd is about another 30 feet.
Ideally, I'd like to cruise at 62-65mph at 1600-1800rpm, and have 72-75mph available for passing/merging.
Am I right in thinking that I'll need 3.73s or 3.91s to get me where I want to be? And is there a formula to tell me top speed in each gear at a given rpm?
I'd appreciate any help to shed some light on this for me.
Don
01-29-2018, 08:28 PM
Chassis: Saf-T-Liner MVP ER
Don
Plug your numbers in here and play to your heart's content
Gear Ratio Calculator
That page has a tire diameter calculator at the bottom too.
01-29-2018, 08:39 PM
Don
A 4.78 will only have you doing around 65 at redline with 11R's.
4.10 would be about PERFECT for you. It would give you 76-77 at redline and 60 mph at 2000 rpm.
01-29-2018, 11:57 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
ohhh, whew. My heart missed a beat- I thought you needed diff eq help.
shoutout for Randy's Rears
01-30-2018, 01:16 AM
Year: 2010
Coachwork: Coach & Equipment MFG
Chassis: ford E350 superduty
Engine: 5.4 liter v8
Rated Cap: 7 passenger
4.10 or 3.73 either is a viable option. and will make that 1st gear a lot more usable.
2010 ford e350 superduty v8 7 passenger bus
01-30-2018, 01:19 AM
Year: 2010
Originally Posted by Rusty
yikes horrors of college just flashed back through my head.
01-30-2018, 07:47 PM
Rated Cap: 34
Thank you, guys, for your input and the calculator.
Food for thought.
Don
01-30-2018, 08:24 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
Do you plan on towing anything?
Gearing for road speed reduces your Towing ability to even pull a car on a bar.
01-30-2018, 10:50 PM
Rated Cap: 34
MAY occasionally tow a 6x8 trailer with a couple of dirt bikes, but no plans for anything heavier.
Even if 5th gear becomes nothing but a flat-country OD gear, that would be okay with me.
Don
01-31-2018, 06:40 AM
my 6th gear on my redbyrd is nothiung but a flat country gear.. has me Taching about 1550-1600 at 65 MPH.. id like to have a little lower gearing than that .. omnce I go up the least little incline I drop back to 5th which has decent power. but you may want to keep your RPMs in that 1800-1900 range in top gear at 65 or your planned cruising speeds.. seems the engines are happier there.. at least my 444E is.
01-31-2018, 07:36 AM
Engine: TE 444
Rated Cap: 12
3.90 would be good
01-31-2018, 07:53 AM
Originally Posted by Kubla
3.90 would be good
thats probably what i need in my bus
01-31-2018, 11:25 AM
Do folks usually swap the entire rear end or do they replace the internals of their current diff?
01-31-2018, 11:41 AM
Chassis: IH
Usually it is far cheaper and easier just to swap out the "chunk" (carrier housing). The only reasons I would swap out an entire axle is:
1. The old one is damaged beyond reasonable repair (as in, I could replace it cheaper).
2. Swapping spring ride for air ride (and the old one won't work).
3. Needing a heavier duty axle.
4. Parts for the old one are no longer available.
5. Swapping Budd/Dayton style rims. This would usually include doing the same on the front axle as well.
06-13-2018, 05:03 PM
Engine: DT 466 Mechanical spicer 6+1. & 5.9 Cummins
update?
Hey was wondering if you actually swapped the rear diff out, I have a 96 3800 with a DT 466 mechanical rated at 190HP with the 4.78 rear and was wondering what your speeds and RPMs are, I have a 6+1 spicer tranny. I want to go to a 4.10 as well but would like to hear about yours first
06-13-2018, 08:56 PM
Rated Cap: 34
Sent you a PM
