Old 08-13-2018, 02:59 PM   #21
I'm not really sure how to proceed at this point.
rube2112 is offline   Reply With Quote
Old 08-14-2018, 02:25 PM   #22
Does anyone know if there's a way to remove the pulley without removing the compressor? I can change the seal with the compressor in place if i can get the pulley off....
Old 08-14-2018, 03:36 PM   #23
usually those pulleys are pressed on.. when I did mine I needed to use a puller which wouldnt have had clearance in between the pulley and the radiator shroud.
its usually dangerous to hammer on a pulley to dislodge it.. you can crack it or bend it. if you have a rubber mallet and its not pressed on too hard it might pop loose by removing the center nut and then tapping on the back side while rotating.. but I wouldnt use a rigid hammer or beat on it hard.. mine was on pretty good but came off easy with the puller..
