Old 06-09-2019, 10:41 PM   #1
Picking up a thatís T444E been sitting a long time,
Well, I finally won a bus! Itís a 2003 international 6 window dognose shorty with only 160k on the t444E with Allison 2000 tranny. She looks great in pics, but sheís been sitting over a year. Even when she was active, she was a reserve bus, not driven daily. Those low miles come at a price I guess.
So, I will likely need to give her a little love before she fires up for me and takes me home (from Austin, TX to Eugene, OR) 2000 miles of break in
Hereís what I know so far from talking to diesel friends and this forum and others:
1. If water has condensed in the tank, it will be at the bottom and I can drain off a little fuel and see how it looks/smells. Not sure exactly what Iím looking/smelling for, but maybe it would be obvious.
2. If air has leaked into the lines, I can crack the seals at the injectors and crank the engine until fuel comes out and then seal em up tight again to bleed the system. Iím wondering if I should just do this, or if I should only attempt if its not firing well on start up?
3. Maybe this should have been 1, but I should check my glow plugs with a voltmeter first thing once battery is charged.
4. I can use Diesel starter fluid, 3-4 cans and just crank until it starts or the battery dies, then maybe even recharge the battery and try again
If I make it through this list, Iíll probably tow it. I just bought a good Sam roadside membership and a stop at the mech is in the budget, maybe even worth it before the drip to make sure its running right and is gonna get me home. Could even pay for itself in fuel mileage if I can get it into an international shop who can unlock 6th gear in my Allison 2000 series tranny and tune it for highway speeds.
Thoughts on my plan? Iíll be flying (with loads of metal for the rock climbing Iím going to be doing on the way), so I need to keep my tool kit minimal. What would you bring in my position? Anyone know the sizes of wrenches involved? What about socket sizes for removing seats?
Hereís the bus for reference: https://m.publicsurplus.com/sms/auct...ew?auc=2348060
Any help is greatly appreciated, Iíve already learned tons on here and canít wait until the carpentry part where I can maybe impart a little knowledge of my own. the build along will be started shortly in the short bus section, cheers! Wish me luck!
Tawdbb is offline   Reply With Quote
Old 06-09-2019, 11:39 PM   #2
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
You're JWilliams
We were 'TheBus'
Glad you scored your ride. We got #3509.
Thanks for posting this thread. I had the same questions and was getting ready to do the same! So.... tag.
- Sharon & Jody
TheHubbardBus is online now   Reply With Quote
Old 06-09-2019, 11:45 PM   #3
Originally Posted by TheHubbardBus View Post
You're JWilliams
We were 'TheBus'
That’s awesome! Glad you scored one as well, we were for sure bidding against some pros too! It was an adrenaline rush for sure. It would have been easy to overbid, luckily the pros stopped at my budget. Where is yours gonna live?
Old 06-10-2019, 12:02 AM   #4
I don't know anything about the T444, but in general,using a siphon hose, siphon fuel from the lowest part of the tank, after it's been sitting, into a clear jar. Water and fuel don't mix and it will be obvious in your test sample. If there is water in there, drain the whole tank and change filters and put fresh fuel in. I would not even think about using 3-4 cans of starting fluid. If it hasn't started with just a little of one can you need to address the issue. Too much fluid could cause damage. I don't know if that motor has a hand primer or not, but if it does, when you think you've pumped enough, pump some more. Cost me $125 to find that out.
Old 06-10-2019, 12:18 AM   #5
Just too be clear, i wasnít thinking of emptying all the cans at once. I think it was on a thread here where someone said to keep using small doses of starter to make the engine fire until the cycling of the engine pulls enough real fuel to clear out the worst of the gunk/old fuel. Still not saying its a good idea, but I believe that was their thought process. My understanding is that diesel can get condensation, and even mold scum, but that the chemistry doesnít really degrade like gas, since its a much less volatile fuel. Iíve read accounts online where diesels sitting for 5+ years had no water and no scum and after a quick prime, fired right up. I hope to be so lucky.
Old 06-10-2019, 01:10 AM   #6
Asetechrail's Avatar
Coachwork: Amtran Genesis
Originally Posted by Tawdbb View Post
Thatís awesome! Glad you scored one as well, we were for sure bidding against some pros too! It was an adrenaline rush for sure. It would have been easy to overbid, luckily the pros stopped at my budget. Where is yours gonna live?
That really is awesome! Two members here getting buses from the same auction while bidding against resellers. They are good looking buses too!
Asetechrail is offline   Reply With Quote
Old 06-10-2019, 03:22 AM   #7
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Ok first off there are no glow plugs on that year there is a intake heater and if you you use starting fluid the heater can ignite it and destroy your motor secondly there are no "lines"to crack in order to bleed the fuel the it sounds like your being told about a idi injection system where as the t444e is a direct injection hydraulic controlled injection system
As for fuel just drain the tank there is usually a bolt on the tank to allow it .as for the fuel remaining in the system get it started and run it out but if there is water/debris that's made it past the filter it's probably already done it's damage and will have to be dealt with regardless but if you really need help starting it I've had good luck with a gas soaked rag over the intake as opposed to starter fluid but if you use starter fluid disconnect the heater grid first .
And get some kind of scan tool that can read live data a scan gauge d is the cheapest I know of .
Congratulations on your new bus
Doe69936 is offline   Reply With Quote
Old 06-10-2019, 03:26 AM   #8
I've bought a few like yours. I'll bet you throw some new batteries in and its A-OK.
My bus was a reserve bus and its a cherry, man.
Roll Your Own Build Thread
Old 06-10-2019, 03:27 AM   #9
The 444E has glow plugs. They did till the end of production.
Old 06-10-2019, 03:34 AM   #10
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
My mistake
