Old 07-07-2019, 01:59 PM   #1
Coachwork: International/AmTran
Chassis: 3000 RE
Engine: 7.3 T444E
Rated Cap: 40 Passenger
Power steering question!
We recently changed the Master Cylinder and Hydraulic Brake lines on my 1999 International 3000 RE bus, and immediately after that job was complete I noticed that the power steering reservoir was filled with foam and overflowing. We tried bleeding the power steering line but that has not helped.
I noticed that the Hydro-Max Brake Booster also assists with the power steering. Therefore, I'm wondering if air from the brake line somehow got into the power steering line? I'm also wondering if I need a new Power Steering Pump or a new Power Steering Booster?
Summ1 is offline   Reply With Quote
Old 07-07-2019, 02:12 PM   #2
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Probably a leak in the lines/fittings sucking in the air
Doe69936 is offline   Reply With Quote
Old 07-07-2019, 02:51 PM   #3
Chassis: 3000 RE
Engine: 7.3 T444E
Thanks for your reply, but we haven't seen any leaks, what is a good way to test the lines/fittings for leaks?
Old 07-07-2019, 03:20 PM   #4
Doe69936's Avatar
Year: 2005
Chassis: School bus
Engine: Cummins
Hmm don't really know a good visual inspection usually finds them
