Old 08-07-2019, 08:45 PM   #1
Rear Diff Tags?
I discovered an envelope today in the cabinet thing above the driver's seat, labelled "Rear Diff Tags". Inside are two tags, one is about 1" x 3" and has the number "02122518" stamped on it. The other tag is about 2" x 4" and has this stuff stamped on it:
CUST PART NO. 3566878C91
RATIO 00617
SERIAL NO HN00904159
SPEC 0729411
PART NO 511345
MODEL 19060SIS (or maybe 19060NS or something)
Also has SPICER in the upper right corner.
Does this tell me anything about my bus? I still don't know exactly what type of transmission I have (I think my seller said it was an MD2050 but I can't find this anywhere; the mechanic who just looked at my bus said it was a 7000-series based on what was written on the transmission but I assume that's 2000-series).
Old 08-07-2019, 09:09 PM   #2
Bon Voyage's Avatar
Engine: Cummins ISC 260/660
Rated Cap: 81
I’m thinking your gear ratio might be 6.17... which is good for stop and go not so good for highway speeds. My old bus had 6.14 but I could be wrong about yours.
I believe Spicer is a brand name for the differentials.
The transmission could be a MD3060 which is a fairly common trans and it’s a pretty good one. I’ve never heard of a MD2050.
How big is the bus and what engine?
Bon Voyage is offline   Reply With Quote
Old 08-07-2019, 09:17 PM   #3
Originally Posted by Bon Voyage View Post
Iím thinking your gear ratio might be 6.17... which is good for stop and go not so good for highway speeds. My old bus had 6.14 but I could be wrong about yours.
The transmission could be a MD3060 which is a fairly common trans and itís a pretty good one. Iíve never heard of a MD2050.
11 windows, DT466. The bus can do 65 and maybe faster (I think anyway - my one trip on the highway I was too nervous to notice my RPMs).
Old 08-07-2019, 10:57 PM   #4
Bon Voyage's Avatar
Rated Cap: 81
It might say on one of your vin stickers what the transmission is. If it is a md3060 there’s a long thread about unlocking the 6th gear so you can get your rpm’s down a little on the highway. It’ll only bring them down a little though like from 2500 to 2250 or so.
On my old Thomas with the 6.14 rear end ratio the rpm’s were at 2500 when going 65 mph. If you notice it next time your out. Those rpm’s don’t make for good gas mileage unfortunately.
Old 08-08-2019, 01:00 AM   #5
A 10% reduction in RPM at highway speeds is helpful for fuel mileage and general wear and tear on the engine.
Old 08-08-2019, 06:17 AM   #6
It might say on one of your vin stickers what the transmission is. If it is a md3060 thereís a long thread about unlocking the 6th gear so you can get your rpmís down a little on the highway. Itíll only bring them down a little though like from 2500 to 2250 or so.
On my old Thomas with the 6.14 rear end ratio the rpmís were at 2500 when going 65 mph. If you notice it next time your out. Those rpmís donít make for good gas mileage unfortunately.
Pretty sure its a 2000 series.
My last bus had the same setup but with 5.29 and I wanted higher gearing.
Roll Your Own Build Thread
