Old 01-03-2018, 10:36 AM   #1
Skipping, dying, gas pedal, 1997 international 3800
Hi. I just bought a 1997 International 3800 deisel bus. I drove it for about 6 hours to a lot near my home. It ran fine. It sat at the lot for 2 months. Then a couple of days ago I drove it to my house and it did fine. The temperature dropped but the lowest it has been is 42 degrees. Last night it was 52 and I drove it about 2 blocks before it started sputtering. Then it accelerated on it's own then died. It cranked right back up and did it about 4 times before I reached my destination. Which was only 5 miles. I stopped to fill it up in case the gas hand was wrong but it only took about $60. So it wasn't running out of gas. Please any suggestions would be awesome.
Rhonda0967 is offline   Reply With Quote
Old 01-03-2018, 12:01 PM   #2
Robin97396's Avatar
Maybe check your water separator on your fuel line. You can get some fuel additive that might help, but it doesn't sound like it's cold enough there to make a problem.
Robin
Nobody's Business
Old 01-03-2018, 01:14 PM   #3
Thanks. We are going to check mat sensor now. My daughter spilled a lot of oil on the manifold yesterday. We were going to check several different sensors.
Old 01-03-2018, 05:45 PM   #4
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
What fuel are you running on. Sensors are money just by mentioning them.
Diesel has its own problems period.regardless of fuel type?
I would start with filters before sensors?
Old 01-03-2018, 09:35 PM   #5
It's a deisel. I found out that algae can grow in the fuel and clog up everything, especially if it sits for awhile. I was told to constantly change the fuel filters and add a bioguard to kill the algae. We cleaned the small basket that was clogged up with wormy looking things and black specks. But I was told it's best to replace both the small and large filter. So I'm going to do that tomorrow. I was also told to put some kerosene in the fuel especially since I was leaving FL and going north. They said that would clean the fuel system. One pint to every 20 gallons is what they said. I guess we will see tomorrow.
Old 01-15-2018, 03:30 PM   #6
Jdawgsfanasty's Avatar
Idk about the algae...wow, but the farmers I used to work for put kerosene in the tractors in the winter...they told it helped prevent jelling...Idk
Jdawgsfanasty is offline   Reply With Quote
1997, dying, gas pedal, international 3800, skipping
