Old 10-17-2014, 03:11 PM   #1
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Spicer 5 speed GVW and towing QUESTIONS
The trans in my bus is a Spicer 5 speed. I think the trans is rated for 50000 gvw on hiway and 35000 gvw off hiway.
My bus comes in at 19000 lbs fully loaded, if I were to tow a trailer how close to the GVW rating can I get? If this helps my engine is the T444e.
I would like to be able to tow upwards of 9000 lbs.
EDIT!!!!!
Trans is Good for 32000-35000 lbs, i have the spicer ES43-5 transmision.
Buses GWVR is 23800 Lbs and the engine must be the 175 Hp model of the t444e as the trans is only good for 180HP.
It will tow 9000 LBS on flat ground (Im not even close to my GWVR) but i don't think it will do well at all in the mountains.... Maybe in first gear but not much else.
"...Baler twine tie downs goin' down the road
On two bald tires and an oversize load..."
Hank's P-O-S is offline   Reply With Quote
Old 10-21-2014, 09:17 AM   #2
Chassis: International 1753
Engine: 6.9 International
Re: Spicer 5 speed GVW and towing QUESTIONS
It all depends on the spicer model that you have. Try and find a tag somewhere.
Old 10-21-2014, 10:50 AM   #3
r_w
Your transmission is probably not the weak link. Allison 545 would be, but that is another story...
r_w is offline   Reply With Quote
International spicer clutch replacement rex_1_mn International | Navistar Drivetrain 5 01-27-2013 07:09 PM
Replace 5 speed spicer with 7 speed spicer (double O/D) frank-id International | Navistar Drivetrain 2 02-13-2011 07:17 PM
1966 Crown 35' 41 passenger 220T Spicer 5 speed $4000 OBO slippers Classifieds | Buy, Sell, Swap 7 12-17-2009 08:57 PM
DTA360 With Spicer 5 Speed Transmission Clunk paul iossi International | Navistar Drivetrain 0 12-11-2009 02:14 PM
1986 bluebird DT466/5 Speed man/2 speed rear code4 Classifieds | Buy, Sell, Swap 2 08-14-2006 11:29 PM
