Old 01-13-2020, 08:41 PM   #1
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
Stairwell heater
2000 AmTran genesis fe dt466. The stairwell heater (Apears to be radiator fluid fed) is now stuck on when the engine is running. The steal plate that covers it gets too hot to touch even after just a 20 minute drive. The hot/cold lever makes no difference. If never used to do this and itís cooking us out in FL after weíve driven. The engine had been off two hours now and itís cooler than it was but still very very warm. Thoughts?
Note: I am no longer selling skoolie insurance. I sold my agency and am traveling N. America full time with my family. Wish us luck!
Serenity Bus Project: OUR NEW EBOOK. ITS A HOW-TO GUIDE. PLEASE CHECK IT OUT! --> https://www.serenitybusproject.com/store/p1/So-Your-Dream-Of-Owning-A-Skoolie.html
HappyInTN is offline   Reply With Quote
Old 01-13-2020, 08:48 PM   #2
My bus has a separate on/off switch next to the driver's seat for the stepwell heater. Did you accidentally switch this on?
musigenesis is online now   Reply With Quote
Old 01-14-2020, 10:52 AM   #3
HappyInTN's Avatar
Chassis: Genesis
Rated Cap: 84lug
Mine has no on/off. It has a hit/cold lever. Neither stops the hot hot heat
Old 01-14-2020, 11:04 AM   #4
there should be a couple water valves someplace.. under the doghouse perhaps that lead to the 1 inch heater lines.. turning those off should completely disable the heating system until you are ready to drive in cold weather again then you can open them back up.. they will look like outside garden spigot handles. or will be red "wing" type handles.
