Old 06-14-2019, 02:39 PM   #1
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
t444e cooling system advice needed. summer trip home.
Wish it wasn't summertime bringing our Texas auction bus home, but it is. We'll be traveling from Austin to Phoenix, and I could use y'alls advice on keeping our bus (6-window, allison 2000) cool.
1) What temperature should I aim to keep the bus below?
2) If it exceeds this temperature, what process should I follow to get it back down?
3) What pre-trip measures would help minimize excessive temps?
4) Is any coolant choice / mix significantly better than the others?
5) Any answers to questions I never thought to ask?
-Sharon & Jody
Mr Beefy Short Bus Acquisition & Build Thread
TheHubbardBus is online now   Reply With Quote
Old 06-14-2019, 02:47 PM   #2
With that transmission you'll likely not have a lot of ups and downs on the gauge. Around 215-220 is normal. I think the engine warning comes on around 230-235 and higher than that it will shut down.
I'd say if it goes up over 220 much back off some.
You'll get a feel for driving it pretty fast especially a long return trip home.
For coolant whatever's in there should be what its supposed to have. There's red, yellow, green, and now blue. Just make sure its full. Top off with the appropriate type if needed. The 444E isn't as critical with coolant. Its a parent bore engine so there are no sleeves or liner seals to worry about. You'll want to make sure it the right coolant with the right ph/additives. But you'll be fine to get it home just make sure its full and check the fluids regularly till you get a feel for the bus more.
Check your oil every fuel stop till you get a good baseline of oil consumption. Its normal for a diesel to lose/burn some oil. I think the 444E's hold five gallons. Make sure you have an extra gallon on hand in case it needs a top-off. I use whatever 15w40 rotella-type oil is on sale. Rotella is really good and I use that a lot but I'm not brand loyal.
Don't overfill your 444E. Just fill it to the full mark. Its ok if its a little over. Too much and it will belch out of the blowby tube I think. I know that Chris told me not to overfill though and he's one smart cookie.
Roll Your Own Build Thread
Old 06-14-2019, 06:25 PM   #3
Coachwork: IC
Rated Cap: 24
Thanks for the info, ECCB!
I've got 5 gallons of oil (+ filter) with me for a complete change before I leave... T6 full synthetic. Going to pick up another gallon for consumption as you suggest. It's possible I won't change it out depending on the last service & what they used, but I won't know that till I get there.
Also prepared to do a full coolant change too... got drain pans, distilled h20, & filter. Same thing... that all depends on what they did and when. But if a change is warranted, I'm curious what mix/type would be suggested to use (If I'm flushing I then have the option to change to something different than what's in there, right?).
-Sharon & Jody
Old 06-14-2019, 06:26 PM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
Won't an oil overfill blow out the main seal?
('Scuse me, still learning.
Just don't wanna end up on the sushi bar at Sea World, for being a slow learner...)
Old 06-14-2019, 11:20 PM   #5
If everything's full and doesn't look ancient I'd be inclined to do the fluid changes at a more convenient place and time. MOST of the time I've gotten a bus the oil looks more or less new. They're usually a little more mindful if you let em know ahead how far you're going to be taking it.
Old 06-14-2019, 11:21 PM   #6
I think it ends up belching out the excess through the crankcase vent tube/blowby tube.
Old 06-15-2019, 07:45 AM   #7
HazMatt's Avatar
Thanx, good to know. There are times I can f@k up an anvil with a rubber mallet!
So, belching oil is socially acceptable.
Farting oil, not so much...
Old 06-15-2019, 10:29 AM   #8
Coachwork: IC
Rated Cap: 24
So, belching oil is socially acceptable.Farting oil, not so much...
Well, I intended to post a picture of a dinosaur passing gas, but I still can't seem to make images work. So... use your imagination (that shouldn't be hard for you, HazMatt)
-Sharon & Jody
Old 06-15-2019, 11:24 AM   #9
HazMatt's Avatar
Dang! A picture that old would have to be either a tintype or daguerrotype...
Old 06-15-2019, 12:56 PM   #10
Coachwork: IC
Rated Cap: 24
LOL. You're a trip. And speaking of which... gotta get ready for mine.
-Sharon & Jody
Old 06-15-2019, 01:05 PM   #11
HazMatt's Avatar
"Shiny side up"
Happy Trails.
Old 06-15-2019, 02:08 PM   #12
CHEESE_WAGON's Avatar
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
'Scuse me, misread a post so here is my REAL contribution...
Oil overfill generally has nowhere to go if all is well with the engine. Most larger commercial diesels have a blowby vent in lieu of a traditional PCV system used on gassers. If you're blowing out out the rear main seal, it will not stop with a simple overflow discharge (not what it is designed for anyway - seals are designed to keep oil IN the engine, where it belongs).
For the OP...
An engine can be air-cooled at high enough speeds, but not likely with this big, heavy and slow of a vehicle. I would open up / remove any installed winterfronts (these are fabric/vinyl coverings on the grille used to help retain radiator heat in cold weather and hinder cooling in the summer). Slower speeds may help as well.
Also, check, double-check and triple-check for any cooling system leaks or other problems before you go, and if you're going a long way, it wouldn't hurt to stop every couple hours and check things over. If all is well with the cooling system and the engine is healthy, you shouldn't have any problems.
"Cheese Wagon" <anomaly.va@gmail.com>
Former owner - 1989 Ford B700 64-pass Blue Bird (Rest In Peace, Cheese Wagon)
Old 06-15-2019, 03:01 PM   #13
HazMatt's Avatar
Thankya, sir! No intent on ever overfilling a crankcase, so I appreciate the informational tidbit.
Got a winterfront that has yet to be used during my tenure. Being in TX, looks like yet another piece of jetsam to be squirreled away for a rainy day.
Or snowy, actually...
For the OP...
Old 07-24-2019, 08:34 AM   #14
PatrickBaptist's Avatar
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
Don't over fill the oil, great way to get oil leaking on the rear or front main.
PatrickBaptist is offline   Reply With Quote
Old 07-24-2019, 09:06 AM   #15
my bus 444E bus came from TX so no winterfront or air shutters lioke the DEV has... in driving at minus 10 degree weather on the highway with all the heaters on blast. i still maintained T-stat temperature. (I run a 180 instead of stock 192).. a winter-front may have helped some but i was in a short sleeve shirt inside.. was a tad noisy driving with all the heater fans on high for hours. but i didnt freeze..
Bluebird defrosters in the post 1994 era are WORTHLESS though..
Old 07-24-2019, 09:24 AM   #16
HazMatt's Avatar
If you want my winterfront, I'd be,
A) Happy it went to a good home and could serve it's function.
B) Delighted not to have to occasionally muck about with it!
