Old 01-04-2020, 12:30 PM   #1
JaFuzz's Avatar
Chassis: Bluebird International
T444E No 'Wait to start' light impossible to start engine :(
Hi Guys!
I was searching for a simmilar problem, but dosn't find any at this forum. After 3 weeks not starting my 2002 3800 T444E Blue Bird, we wanted to prepare everything to move our BlueBird Home from South Portugal to Spain. I tried to turn Her on, but first thing, which I recognized, was that there is no 'Wait to start" Yellow light after turning the key... Injectors made clicking sound, but, when i wanted to start nothing happened. Only relay clicking sound. I checked the Voltage of batteries and it was a little to low. I charged batteies, tryied again and it dosnt help. No Yellow 'Wait' light, only relay clicking sound (yes, I checked automatic transmission is in Neutral)
When im turning the starter key, lights are turning off... checked battery cables, everything looks ok... maybe starter finished its life? But why 'Wait' light is not flashing? Could You help me?
JaFuzz is offline   Reply With Quote
Old 01-04-2020, 12:50 PM   #2
It is normal in most vehicles to cut power from everything not needed when engaging the starter so all the amperage goes to the starter, lights come back on when key is released.
Old 01-04-2020, 05:35 PM   #3
Johnny Mullet's Avatar
Engine: T444E 7.3L
Sounds like one or more of the batteries are bad. A bad battery ccan still read 12 or more volts on the surface.
Old 01-04-2020, 05:42 PM   #4
dead battery or blown ECM fuse..
no WAIT light and no test of the WARN light means the computer never booted up...
Old 01-04-2020, 11:32 PM   #5
JaFuzz's Avatar
Batteries are holding 13V
Old 01-05-2020, 01:53 AM   #6
JaFuzz's Avatar
Ok, I will check it. But, as You wrote, if computer doesn’t bot, is it normal that I can hear injections clicking?
Old 01-05-2020, 02:21 AM   #7
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
I've never heard injectors click with key on on a 7.3l/T444E. Or any engine really for that matter. Are you sure it is coming from the engine and not from something else, like the ABS modulators or an electrical box?
Truthseeker4449 is offline   Reply With Quote
Old 01-05-2020, 06:11 AM   #8
on my 444E hydraulicbrake bus when I go key-on.. I hear the glowplug relay kick on, the brake motor of course runs, the ABS controller clicks all channels, the allison TCM seems to click some solenoids in the transmission.. sounds like there is a little click or 2 up near the glowplug relay.. im guessing it cycles the IPR solenoid.. then all the clicking is done after a couple seconds.. there is the buzz ofthe brake motor and after as minute or so the glowplug relay clicks off..
when my computer is in a no-boot scenerio (if I pull one or both ECM fuses).. then I dont get the glowplug relay or extra click near the heads, but I get the rest..
Old 01-05-2020, 09:38 AM   #9
JaFuzz's Avatar
Ok, I’ll check again tomorrow. Thanks for Your answers. Where to find those ECM fuses?
Old 01-05-2020, 10:52 AM   #10
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
Check out this thread:
http://www.skoolie.net/forums/f49/fu...elp-29780.html
read till the end.
Old 01-06-2020, 02:28 AM   #11
JaFuzz's Avatar
read till the end.
Thanks, I’ll check this hidden fuse box today.
Old 01-06-2020, 02:38 AM   #12
JaFuzz's Avatar
(...) when my computer is in a no-boot scenerio (if I pull one or both ECM fuses).. then I dont get the glowplug relay or extra click near the heads, but I get the rest..
Where are You finding those ECM fuses?
Old 01-06-2020, 07:13 AM   #13
JaFuzz's Avatar
I’m not able to find this aluminum fuse box. Maybe someone before me changed something :/
I checked starter, relays, fuses and now I’m sure, that my computer is not boring at all. This clicking sound was connected to ABS.
Old 01-06-2020, 07:30 AM   #14
my bus is a conventional.. and on the dash behind a black panel is a fuse box.. it has one marked ECM BAT and one marked DIAG, those are the fuses for the computer..
Old 01-06-2020, 08:19 AM   #15
JaFuzz's Avatar
Mine is also conventional, but I don’t have ECM BAT, only DIAG. Checked, all of them are ok.
Old 01-06-2020, 08:23 AM   #16
Engine - apparently they changed the name..
next on the list would be the relay bank on the firewall under the hood .. there is a power relay and a Starter-enable relay.. (I dont have my books in front of me to see which is which)... the power relay must enable for ther computer to come to life..
its **POSSIBLE** someone wired a bus interlock - say a Vandal-lock on your back door or side door.. to this relay.. so if your back door was locked it would disable the engine of the bus... or the relay could be shot..
Old 01-06-2020, 03:00 PM   #17
JaFuzz's Avatar
I've checked those Relays today, two of them are 'clicking' afther turning starter key, one is dead .... tomorow I'll check them with Multimeter... thx
Old 01-06-2020, 05:03 PM   #18
Rated Cap: 26 foot
Sorry if I confused you with the link. I knew we had different bus chassis, and I should have said so. I just meant to show you some things to look for and how you might find them, and point to further links where you might find diagrams.
Good luck!
Old 01-07-2020, 02:37 AM   #19
JaFuzz's Avatar
Good luck!
In my case, every trace and idea is important. Mechanics here don't want to work with this engines because they don't know them. So your help is very important for me.
I’m still thinking is it a possibility to give voltage to ECM straight from batteries. Now I need to move bus 500km to next place, where we plan to stay next 2 years. So it’s important to me to start him.
Old 01-07-2020, 05:58 AM   #20
on the fireweall, 2 of those relays are for the computer and one is for the transmission (if i remember right).. just because they click doesnt mean they make contact..
does your dashboard go through its self check? (the needles go up then back down?)
