Old 06-01-2011, 08:13 AM   #1
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
T444E Redline Question ...
Okay, so I've been trying to find out what a safe 'top' RPM is for the T444E. I've read online that it's 2200, but then I've found technical data that says that the 'power band' is right around 2100-2300.
So, does anyone know what the redline should be so I can stay safely below it?
Hex is offline   Reply With Quote
Old 06-01-2011, 10:53 AM   #2
frank-id's Avatar
Re: T444E RPM
My BB has a 7.3 engine also. These are hi speed diesel engines to can be safely operated up to 3600 RPM. The power band seems to be about 2500-3000 RPM.
These engines are very tough with only the valve train as a weakness. There is no difference between pulling a long 6% grade and moving down the road at 70MPH. This type engine must have good cooling to survive. Frank
Old 06-01-2011, 12:03 PM   #3
Hex
Hex's Avatar
Rated Cap: 42
Re: T444E Redline Question ...
Well, that would be cool. I've not gone over 2500, and the temp never gets above 180-190 degrees. But if I can go higher safely than 65 mph will be no problem even with the gearing I've got ...
How do we all feel about the T444E? thechandler Conversion General Discussions 34 09-20-2020 09:46 AM
Specs and tweaking a t444e? JeffD2u Mechanical and Drivetrains 21 09-16-2018 06:34 AM
T444E vs. Cat 3126 M1031 Mechanical and Drivetrains 5 04-18-2014 08:26 AM
!997 3800 T444E chev49 Alternative Fuels | Electric, Propane, Wood & Biofuels 3 04-25-2012 05:32 AM
Detroit 8.2L redline?? reddog GM | Chevrolet Drivetrain 1 12-23-2010 06:58 PM
