05-29-2019, 09:52 PM
T444E Slowly Lost Power, Now No Start. HELP!
I've got a 2001 International 3000 with 7.3l t444e engine. I recently took it for a spin around the block and as I was leaving the house and climbing a hill, the bus starting losing power. Got up to 25mph then very slowly started falling. Pulled off, turned around and limped home. And when I say limped, I pulled into the driveway idling. Warn Engine light came on then engine shut off. Started it back up a few times, it seemed to idle fine but as soon as I put it in gear same thing, warn engine light and shut off. Then starting idling rough and now nothing. Engine turns over fine but won't run.
I replaced the fuel filter and removed and cleaned the strainer. Changed the oil and filter, figured why not while I'm getting dirty. Coolant level is good. From what was in the fuel strainer (maybe 1.5 oz) there were a few drops of water but i never got the "Water in fuel" light. There were also quite a few chunks of debris in the strainer but didn't seem significant given that it probably hasn't been cleaned in a long while. We did a 5k mile trip last summer and she gets regular trips every few weeks. Haven't had any issues until this!
I've got another big trip planned in a few weeks and need help! Here's what i'm thinking of troubleshooting:
1) Water in fuel (about 1/3 tank in there now, filled about 6 months ago). This bus doesn't have a fuel/water separator, seems to all be handled at the main fuel filter above the engine
2) Bad fuel transfer pump
3) Fuel line blockage. Fuel gets to the filter OK, maybe after the filter?
I'm trying to get a mechanic out to look at it, I really don't want to cough up the $$ for a tow if i don't have to! I've looked through the threads and worked on as much as I could from what's already here, hoping someone has dealt with the same issue.
05-30-2019, 02:12 AM
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
not familiar with engine management
If you are going to own this kind of rig, can you purchase the needed computer software that would enable you to check stored fault codes in the ECM and or TCM ? Is there a way to be able to watch injector on/off time for each injector and or other engine parameters that you could access? If you had this ability, would you know what you were looking for? Long run will a tow be cheaper/faster?
william
05-30-2019, 06:10 AM
Engine: T444E 7.3L
Does the bus have a Diagnostic button on the dash? Only way to find want went wrong is to get the trouble codes set when it died.
05-30-2019, 06:19 AM
How many miles are on the engine? That, to me, sounds the same as my t444e which had failed injectors. Mine had 160,000 miles.
05-30-2019, 06:31 AM
Year: 98
Yes. On a power stroke..lift pump... Schrader valve on fuel bowl filter. Connect a 100 psi gauge that you can monitor while driving.
The check engine light is triggered by negative pressure caused by fuel filter restriction. The lift pump pushes thru the filter and the second piston pump puts at 70 psi to the fuel rails.
Good luck
05-30-2019, 07:16 AM
Good luck
the 444E varies a bit from the ford 7.3, they kept the old CAM-based mechanical fuel pump as the only means of lift from the tank to the rail.. I dont remember seeing any sensors for fuel pressure and there are no PID;s in the computer for it.. it does pressurize the rail to a pulsating 65-70 PSI as joe mentioned at the test schraeder under the hood.. I think it needs a minimum of 30-35 for the engine to idle.. since its a mechanical pump you'll notice your test gauge pulsate up and down as you crank..
But first follow Johnny Mullet advice, press the diagnostic button and get the codes out of the ECM and see what it thinks the trouble is..
05-30-2019, 08:16 AM
Thanks, will do. I ordered the code reader as soon as it happened. Should have it here today to see what codes i'm getting. No diagnostic button on the dash, have to plug in at the engine. It's a pusher with 190k miles. Also grabbing a pressure tester today to see what we've got there.
Did just that, will post what i get when it comes in (hopefully today)
05-30-2019, 08:17 AM
No button on the dash but will get them read today at the engine in the back.
05-30-2019, 08:20 AM
Good luck
Is it possible that the pressure could read OK but there's a restriction past the pump? Or am i thinking about this wrong and the system is in a loop so entire system pressure will be low regardless of where the restriction is?
05-30-2019, 08:23 AM
Good luck
The diagnostic manual says in a no-start situation to crank the engine for 20 seconds to read the fuel pressure. Seems like a lot on strain on the batteries...
05-30-2019, 10:06 AM
its a good idea to have a charger handy when diagnosing issues.. they want you to crank it a decent amount of time to make sure the pump builds and holds poressure... since it is mechanical you will be watching peaks and valleys in your pressure reading as the gauge bobs up and down
cranking for 20 seconds also makes sure the HPOP has had time to fill back up if it drained for some reason.. these engines have 2 oil pumps.. one is the regular Lube oil (your dash gauge pressure).. and the High pressure (HPOP) which is engine oil used as hydraulic fluid to actuate the fuel injectors..
the lube opil pump fills up a reservoire which the HPOP sucks from to build its high pressure oil.. if that reservoire goes empty (ie you ran the engine out of oil).. then the engine fails to run.. cranking 15-20 seconds usually ensures there is oil back in the HPOP reservoire so it would start..
05-30-2019, 09:43 PM
Thanks Christopher. I've had a charger hooked up to the batteries and they're holding steady. I cranked the engine with a gauge on the fuel valve. After about 20 seconds i had a little under 30 psi. The manual says a minimum of 20psi so I assume this means the filter is free of obstructions and the transfer pump is doing its job. Maybe an issue with the injectors now or high pressure oil pump?
05-30-2019, 10:51 PM
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Question - I see mention of the HPOP here, which I presume means High-Pressure Oil Pump. Is this a HEUI-style engine? I only ask because I didn't think these had this this early. It's a 2001, correct?
05-31-2019, 04:11 AM
They had em since 98 or so. Ever since switching from the IDI.
05-31-2019, 04:24 AM
Traveling
Year: None
Coachwork: None
Chassis: None
Engine: None
Rated Cap: None
Good to know. I thought the IDI engine ran into the early 2000s.
05-31-2019, 07:44 AM
1994 was the first model year for the T-444E HEUI engine. somewhere in 95-96 the DT-466E came out with HEUI also.. the CAT 3126 also came out in the mid late 90s.. 97/98 I think which it was HEUI.
some of these engines continued their mechanical for mas overlap for a couple years..
ive seen m,echanical DT-466 busses with a 98 model year, and ive seen DT-466E based busses with a 95 model year.
I know ford switched from the IDI to the T-444E (powerstroke 7.3) in 94 and didnt offer the mechanical anymore.. I dont know if international still sold the 7.3 IDI alongside the 444E or not..
I think the last year for HEUI was in 07/08 when the DT-466E switched to the MaxxForce DT and was no longer HEUI..
the VT-365 was the last HEUI V8 .. when the infamous Maxxforce7 was released in 07/08 it was not HEUI (aka the ford 6.4)..
OK BACK ON TRACK
one thing that needs checked with any crank no start on a 444E are codes for the crank position sensor.. if it fails the engine cant sense its RPM nor where the stroke is so it will fail to fire the injectors.. reading the codes should show an error... otherwise the only way is with a scan-tool.. the scan-tool will read RPM while the engine is cranking.. if it stays 0 then the CPS is the first place to go..
05-31-2019, 07:52 AM
I agree a CPS is possible. But if one of those fail the engine just shuts down, not slowly losing power.
05-31-2019, 08:59 AM
OK BACK ON TRACK
Tach is moving on start up so now i'm leaning away from the CPS being the issue. It was a gradual dissipation in power to the no-start.
I was looking around the bus this morning and just had an 'oh shoot' moment... The day the problem happened I was welding on the roof of the bus, putting up a roof rack. Welding cables grounded to rack, but could the current have possibly fried the ECM? Didn't disconnect batteries when i was welding...
05-31-2019, 09:02 AM
Chassis: IH 3800, 8 window
Wouldn't think the ECM was in the voltage's path.
Sure hope not, that's prolly a few more amps than it was designed to carrry... 🤞
