03-19-2019, 07:21 PM
T444E won't start consistently
Hello.
I recently purchased a school bus with T444E engine in it. It was working well until the deep cold hit. It was sitting in under 0 temps for a couple of days in wisconsin. I had the batteries charging and the block heater plugged in all winter but now every time I want to start it it takes up to 10mins of me turning it on and off to start. It will crank every time but doesn't start until my 15th or 20th try. We checked the oil and it seems fine and has plenty of gas. Any suggestions?? We also recently took the AC unit out if that helps
03-19-2019, 07:55 PM
AC unit wont affect starting.. so you are saying it fails to start even with the block heater hot? can you feel that the area around the block heater is warm? (that the block heater didnt die)..
if you pull the cap off the fuel filter bowl on top of the engine is it full of fuel?
if it starts easy with block heater on and not without, then the glowplugs or glowplug relay are suspects.. does your WARN light stay on? or just goes on and then off when you cycle on the key?
03-19-2019, 07:58 PM
I added Fuel Additive to help the diesel from gelling in the real cold temperatures.
https://powerservice.com/psp_product...-cetane-boost/
You may also want to check the filters.
- Roger (Dog.Rescuer)
03-20-2019, 10:32 AM
So yes the block heater is putting off heat and it is full of fuel when I pull the filter out. The warn engine light comes on when I turn the key then goes away. Even after I've had the block heater plugged in for a day it still won't start until the 10th try
03-20-2019, 10:36 AM
Also when I checked the oil just now it was covering full. So could it be gas leaking into the oil?
03-20-2019, 12:13 PM
Disregard the oil comment. Bus wasn't level . Blonde moment
03-20-2019, 01:53 PM
Cold start issues on a T444E, my first place to look would be the glow plugs. It's an easy diagnosis. When you turn the ignition on and the "wait to start" light comes on, you should see your voltage needle plummet. Those things draw around 100 amps of power which will put your needle under 12, maybe even to 10. If your needle doesn't do that, they're likely not engaging.
The easy test to be sure that's the problem is to bridge the glow plug relay (solenoid actually). There are 2 large wires and 2 small wires that connect to it, you need to connect the two large ones together for about 15 or 20 seconds (colder temp = longer connect) with the ignition in the "on" position. You can do this with a plastic handled screwdriver or even jumper cables, something that can handle a bunch of juice without shocking you. It should fire right up after that.
Your relay likely look like either this: https://amzn.to/2Hv0RXL
or this: https://amzn.to/2Yagwks
The second one is what I used to replace mine when it failed.
03-20-2019, 03:07 PM
Thank you so much! I will test that today and let you know. Also I'll absolutely check your build out!
03-20-2019, 04:13 PM
wierd that its a no start with the block heater plugged in.. almost starting to sound like an HPOP draining down... that will give very long crank times..
Brokedown's idea of testing the glowplug relay is a definite good place to start..
03-22-2019, 12:07 PM
So the voltage was good. I got it started after a while and it was working fine for a while. Then today it won't start again. The glow plugs and relay are all good to my understanding. What is hpop?
03-22-2019, 12:31 PM
Rated Cap: 35
HPOP is High Pressure Oil Pump
03-22-2019, 12:34 PM
Okay so you think that's the issue?
03-22-2019, 01:08 PM
the injectors are actuated by the computer and also Hiugh pressure engine oil.. your engine has 2 oil pumps.. the usual one (which shows on your dash gauge), and the High pressure or HPOP, the HPOP reservoire is filled by the regular oil pump.
the HPOP reservoir has to have oil in it or the injectors wont push fuel into the cylinders.. it is possible that its draining down after the bus sits for a time.. soi then you crank and crank which allows the regular oil pump to re-fill the HPOP..
the other possibility I thought of is an injector or injector O-ring allowing the fuel in the rail to drain out.. most likely you would notice a fuel smell in your oil... and / or your oil level going up above normal even if you filled it to normal fill level...
03-22-2019, 08:25 PM
Engine: T444E 7.3L
Does your bus have a diagnostic button on the dash anywhere? Maybe you have a code stored the the computer that could help?
12-31-2019, 03:26 PM
Chassis: T444E 3800
Engine: 7.3 Turbo Diesel
High all! Sorry if I am not doing this right, but I have a question on this engine too. We just bought a 2000 T444E 3800 and am about to change the fluids. I saw a video of a man changing a 7.3 power stroke and he had to pull oil from the high pressure oil pump, but I don't see one on my bus. Is there one? If so, does oil have to be drained from it?
12-31-2019, 03:58 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
slow down a little bit and figure out what you have, before you start pulling things.
the HPOP high pressure oil pump is your diesel fuel system pump and only needs to be worried with if you dont change your fuel filters correctly ,the pump is messing up or upgrading the pump.
normal fluid change does not include diesel fluid because you do that everytime you fill your tank and only a filter replacement will be needed at periodic increments.
normal fluid and filter changes do and will vary alot between each system including the type of fluid and filter you choose?
example not fact or specific brand.
oil change every 3000 miles with conventional oil or 6000 with synthetic. but truth be known its up to you when check your oil and the color of it? if it looks dirty then it probably is.
keeping your antifreeze in its correct range is on the top of the list and a good flush wont hurt anything.
FOR THIS i might get some slack but i have to many to count so i will never do it again.
if your transmission has any age on it?
you can change your transmission fluid and if your filters in the pan.
just drop the pan,change the filter but dont clean the sediment out of the bottom of the pan?
it is actually in a long story short part of the transmission that needs to be circulated in the fluid.
they make a zinc addittive that is supposed to cushion the bands in the transmission but that is in conjuction with whats already in the pan and dont ever let a shop sell you a transmission flush unless they guarantee mileage or years and if they do you need it in writing before you pay them.
12-31-2019, 04:04 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
also johnny mullet is the 7.3 man and should be along shortley.
not all diesels are the same but the principal idea is.
12-31-2019, 05:59 PM
Chassis: MVP ER
Engine: CAT 3126
Is he now? I'll have to remember that the next time my truck breaks down. It's only been towed 5 times in the 15 months I've had it..... I haven't even put over 6,000 miles on it yet. Thus is the life of the old body style Ford.
12-31-2019, 06:47 PM
Johhny is the man on the T444e, not only does he have one in his bus, he works on them for a living.
12-31-2019, 07:06 PM
Year: 86
Chassis: Ford B700
Engine: 8.2
my personal truck is a 77 ford supercab with the 400 or 6.6 or boat anchor or whatever everyone wants to call them?
seem to have a nack for making the old boat anchors run.
taught my oldest son to mechanic working on that truck and now he is a ford mechanic, so if johnny cant help which i doubt then maybe i can through my sources and advice but johnny is first hand and i will only be second or third hand knowledge.
