Old 11-24-2018, 05:33 PM   #1
Rogue1bus's Avatar
Type of fluids (at & coolant)
I have a 2002 international Amtran re with a 7.3l engine and 545 transmission.
I am trying to figure out what coolant type and at fluid my bus takes.
Thanks
Rogue1bus is offline   Reply With Quote
Old 11-24-2018, 05:38 PM   #2
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
For coolant you will want anything that says "Cat EC-1", check the dip stick for the trans fluid likely printed on there.
Edit: Unless what is in there is green stuff like normal Prestone, then you need to find out the last time your coolant filter was changed and if it was pre charged. If no clue you need to test it for the correct levels etc
bigskypc50 is offline   Reply With Quote
Old 11-24-2018, 07:35 PM   #3
Rogue1bus's Avatar
I used this, pretty sure itís right.
Old 11-25-2018, 08:56 AM   #4
Originally Posted by Rogue1bus View Post
Attachment 27576
you are year 99.5+, you can use ELC coolant in your T-444E, the green stuff with SCA charge will work too, im using an AMSoil coolant in mine.. no more SCA to worry about..
Old 11-25-2018, 11:36 AM   #5
Rogue1bus's Avatar
[ATTACH] 27578[/ATTACH]And this for the transmission.
Old 11-25-2018, 11:37 AM   #6
Rogue1bus's Avatar
Iím not sure what was in it before, the expansion tank drained out when I relocated a heater, any issues if the stuff I got mixes with other coolant?
