Old 09-20-2016, 09:16 AM   #1
Engine: t444e
Visual difference between dt466 and dt466e
Is there an easy way to tell these two apart at a glance? thanks
I think on the driver side the E version has the big box up top on the motor and the mechanical doesnt?
ChiliChzPoopTart is offline   Reply With Quote
Old 09-20-2016, 09:40 AM   #2
GreyCoyote's Avatar
Chassis: IH 3800
Engine: Navistar DT466E
Rated Cap: 72 passenger
The 466 mechanical has an inline pump with six hardlines exiting it and going to the injectors. It has no ECU and no diagnostic connector.
The 466E has a modular pump, with a single high pressure line. It has a sizable ECU mounted on the drivers side of the engine at shoulder height. It also has a valve cover that integrates the intake manifold (ie, there is 4 inch hose coming off the intercooler and going right into the valve cover. It will also have a grey 6 pin diagnostic connector under the dash by the drivers right knee.
"You can finally say you have enough horsepower when you leave two black streaks from corner to corner"
(Mark Donohue, famed TransAm driver)
GreyCoyote is offline   Reply With Quote
Old 09-20-2016, 09:58 AM   #3
mechanical
"E"
Roll Your Own Build Thread
Old 09-20-2016, 01:10 PM   #4
crazycal's Avatar
That's a pretty blue.
I'm hungry!
You Gotta Let Me Fly
Old 09-21-2016, 05:43 AM   #5
Engine: t444e
Gracias gentlemen
