Old 04-26-2016, 03:46 AM   #1
timbrass's Avatar
Location: Henley-on-Thames, United Kingdom of Great Britain and Northern Ireland
Rated Cap: 29
What does this port/hole do?
Any idea what this port/hole on the side of the Transmission does? Should it be covered with a plug?
I believe it is an Allison 2000 Transmission on a DT466e
Whilst sorting out the rust I spotted this port/hole on the side of the transmission? You can see "toothed gearing" inside. Doesn't seem right that this is exposed to the open air! Also surely Transmission Oil could escape from it?
On the other hand it doesn't have a thread on the inside of the hole to take a screw in plug....
Should I leave it as it is or plug the hole somehow?
2nd photo take from ground level underneath the passenger door.
My Build site is https://schoolbusconversion.net
timbrass is offline   Reply With Quote
Old 04-26-2016, 08:28 AM   #2
2kool4skool's Avatar
That hole is in the bell housing / convertor housing. No harm.
Don, Mary and Spooky the cat.
Old 04-26-2016, 08:52 AM   #3
Engine: Cat 3126b 250 HP
Rated Cap: Only 1 seat
I am no allison mechanic, but I am very confident it is an inspection port.
Old 04-26-2016, 11:49 AM   #4
timbrass's Avatar
Rated Cap: 29
Thanks. I decided I needed to know a bit more about Transmissions so I watched this!
