Old 03-22-2015, 07:49 AM   #11
Chassis: B3800 Short bus
Originally Posted by onenationundergoat View Post
Also the battery gauge indicates that the alternator isn't charging all the time. It'll work some and then drop down, so I'm not sure if it's the gauge itself or the alternator.
Check the belt tension before doing any other diagnostic work with the alternator. If the tensioner isn't keeping the belt tight enough then all the engine driven accessories will suffer..
Old 03-22-2015, 09:45 AM   #12
Engine: 190hp 5.9 Cummins
Originally Posted by crazycal View Post
Courtesy of Elliott.
http://www.skoolie.net/forums/f33/ho...pecs-1641.html
If you don't post pics of your bus, it doesn't exist.
I second this. Pics or it didn't happen.
Old 03-22-2015, 09:39 PM   #13
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
Workin' on pics... Smashed my camera into a boulder last fall so I'm working with a flip phone here...
Also I just looked at the maintenance records and discovered I have a DT360 instead of a DT466. What a sad revelation. But no worries! Guess I'll just be a slowpoke. =]
I was talking to the bus garage guy about the DT466 the whole time and he never gave any indication that it was different than the one I was buying. I should never assume things.
onenationundergoat is offline   Reply With Quote
Old 03-23-2015, 12:19 AM   #14
Chassis: Thomas
Rated Cap: 60
Ok let's see if I can get this to work!
Bus vs. Pop-up camper
Here's a very rough mock up of what the conversion will look like. The will be a claw foot bathtub in the living room with a repurposed door sitting on top with cushions available to make a bed, couch, table, or bathtub! A gas log fireplace in the living room/kitchen area. The bedroom will have two bench couches with storage underneath and the storage doors will swing up and connect to make one large bed. The back mud room will store animal food containers, the dog crate, and a dryer to be run from a generator. It's somewhat of a necessity with our messy lifestyle. The whole back area is a grated washable floor for the goat, rabbits, and chickens.
Old 03-23-2015, 07:04 AM   #15
Chassis: I.H.
O.k. If mine is a dog nose front, what is this called? A pug? I saw a few when I was looking for mine.
Old 03-23-2015, 09:04 AM   #16
Coachwork: Ward/Amtram
Chassis: International 36ft
Engine: DT466 w/ Allison MT643
If you're running at 2800rpm, i wouldnt increase the governor, could damage the engine with such high RPM, not to mention your fuel economy would hurt.
You need an overdrive and/or taller rear gears. Identify your transmission and we can go from there.
dalez is offline   Reply With Quote
Old 03-23-2015, 10:11 AM   #17
Sustained RPM's in excess of 2,600 RPM's can cause some real damage to your DT466.
Regardless of which transmission you have you should be able to handle rear gearing in the high 4's.
If you send me a PM with your e-mail address and the VIN of your chassis I might be able to get the build sheet for your bus. It will tell you what was used to build your bus--which engine, which transmission, which axles and brakes, which rear end ratio, etc.
There should be a tag on the driver's side of the transmission that will tell you which transmission is in your bus.
Unfortunately a lot of the data plates for engines were not made of metal with stamped numbers but an electronically produced label printed on a plastic tag. Over time they tend to lose their legibility.
You may find the line setting ticket affixed to the under side of the hood just above the hinge on the curbside of the bus.
Good luck and happy trails!
Old 03-23-2015, 06:14 PM   #18
Dam that pug nose is fugly.
You have Dayton style wheels, how about taller tires?
I have swapped back and forth between 20 inch and 22.5 Dayton rims. Do 24.5 Dayton wheels fit also?
Old 03-23-2015, 06:23 PM   #19
Year: 92
Coachwork: ford
Engine: 6.6 Ford
Rated Cap: 3
If it's a DT360, there's a 90% chance it's an AT545 Allison.
I vote to change the rear gears, and put in a better trans.....and hike up the power.
nevrenufhp is offline   Reply With Quote
Old 03-23-2015, 07:10 PM   #20
Chassis: Thomas
Rated Cap: 60
The VIN# is 1HVBDPLN1PH485283
In the maintenance folder they gave me there is an outdated oil analysis record from 2011. The bus was running last fall, but apparently has only been 13,000 miles since this 2011 report. In the report it says that there were abnormal levels of copper and lead detected, and severe problem levels of sodium and potassium. It says "severe level of coolant glycol has been detected. check engine for over heating and coolant loss. monitor closely. corrective action should be taken as soon as possible." I called the bus garage about this and they said they might be able to find some more records, but that there's no way the bus could have run for another three years without them fixing it.
Today we checked the oil dipstick and there was plenty of creamy vapor deposit on the stick. We've had the bus less than a week and have only had it up to operating temp once, so it could be from that, but it also could indicate a coolant leak. We couldn't find out how to check the coolant level, but a finger in the well doesn't touch any liquid.
This isn't sounding very good. =[
I have room in the budget for maybe around $500 worth of repair work to get her in good running condition. As for the tire size suggestion, these tires are new retreads and very good tread on the front tires, so I wouldn't like to buy more. I'm considering putting in a new rear end for a better gear ratio. I see one on Craigslist nearby for $300. Any chance I'd find one cheaper?
