Old 03-24-2015, 09:27 PM   #31
Engine: TE 444
Rated Cap: 12
you still need to find out the axle ratio, you can call a big international dealer with the serial number and he will tell you what axle ratio it left the factory with, my dealer actually printed out the chassis build sheet for me on my 97 with all that cool info since you will need to know which rear axle you have to buy a differential with a different ratio
Old 03-25-2015, 09:00 AM   #32
You have the 170 HP version of the DT360.
You have 6.14 gears which are going to give you a top speed of around 50 MPH.
And you have the Allison AT545 transmission.
cowlitzcoach is online now   Reply With Quote
Old 03-25-2015, 01:26 PM   #33
charles_m's Avatar
Year: 1982
Chassis: International S1800
Engine: DT466 Trans: MT643
My 466 only make 180 hp
The 6.14 is a bummer though
www.bustoshow.org
Blog: www.lookatthatbus.com
Instragram: @lookatthatbus
Old 03-25-2015, 02:41 PM   #34
onenationundergoat's Avatar
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
If I switch it out for a 4. something would my engine be fine for that? Or even anything midway if there is such a thing?
onenationundergoat is offline   Reply With Quote
Old 03-25-2015, 04:53 PM   #35
Engine: 190hp 5.9 Cummins
I'm not sure what your asking.
Mine has 4.44 gears. Was that the question?
Old 03-25-2015, 04:56 PM   #36
Chassis: Thomas
Rated Cap: 60
Would my bus have a hard time with the 4.4 gears? I was asking if there's a 5 ratio or only a 4.4 and mine.
Old 03-25-2015, 06:50 PM   #37
crazycal's Avatar
Is NC flat like Kansas?
I'm hungry!
You Gotta Let Me Fly
Old 03-25-2015, 07:02 PM   #38
Chassis: Thomas
Rated Cap: 60
Well there's the Appalachian Mountains... so no. Then there's the foothills, where I live. It's relatively flat but not Kansas flat. Then there's the coast, which is definitely flat.
Old 03-25-2015, 09:19 PM   #39
crazycal's Avatar
I was trying to be funny and not doing a good job. The taller your gears are(lower number, more highway), the more powerful your engine needs to be to keep your bus moving at highway speeds, especially when you hit the hills. If your bus had a 10 speed like some of the older buses, you could keep your rpms in that sweetspot and not lug your engine everytime you hit a hill.
Simplistic answer from the simpleminded.
I'm hungry!
Old 03-25-2015, 10:36 PM   #40
My 195hp DT466 does fine with the 4.44's. They would be an improvement for sure in my opinion. You could eke out a few more hp from the engine too to help in the steep stuff.
You definitely want higher gearing for road trips man.
