01-16-2018, 09:53 PM
Engine: Dt466e
Rated Cap: 71
which t444e is it
so if i understand right, im reading that there are different HP varients of the t444e. is there a way to tell which one a bus has? i have the vin, no pictures available yet, i have sent requests but bus may not be available yet
vin 1HVBBABN21H407087
one sit says this is engine 7.3L V8 OHV 16V DIESEL/CNG if that helps
01-16-2018, 10:10 PM
Chassis: Saf-T-Liner MVP ER
You'll have to contact an International dealer with the VIN# to get more info.
The Gates VIN Decoder doesn't mention CNG.
01-16-2018, 11:02 PM
Rated Cap: 37,400 lbs GVWR
Are you sure you want CNG? It's either diesel or CNG, not both.
01-17-2018, 06:08 AM
Auction listings very OFTEN say Diesel/CNG.
01-17-2018, 06:25 AM
Engine: Dt466e
Rated Cap: 71
The ad and 2 websites I used for vin didn't say cng, one vin decoder did. I'm not sure what it is honestly
01-17-2018, 06:34 AM
On online auctions, they're often listed as diesel/cng as they were available that way. Something to do with folks not knowing much about buses. They're secretaries tasked with describing mechanical things in a listing.
01-17-2018, 06:44 AM
THere is a tag on the passenger side valve cover that will clearly show which tune it has... But good luck getting an auction seller to look at it!
01-17-2018, 06:47 AM
Engine: Dt466e
Rated Cap: 71
Dealer not auction, so I'm hoping for some luck with more info. Bus showing not available for a month though so we shall see if they even have the info
01-17-2018, 06:50 AM
Googling the VIN, I found a listing for it saying its a diesel.
01-17-2018, 07:12 AM
Engine: Dt466e
Rated Cap: 71
Lol. No way to keep postings from people. So I guess cng is a different fuel type? Still learning
01-17-2018, 07:13 AM
Compressed Natural Gas.
01-17-2018, 07:23 AM
Engine: Dt466e
Rated Cap: 71
Gotcha, yeah don't want that. I'll stick with diesel...hopefully they have more info on tune/trans/vehicle condition and I can get some pictures.
01-17-2018, 07:24 AM
Best of luck man.
A 444e isn't my first or even second choice for an engine in a full size bus. But if its a 230hp version with a better transmission than the 545, it would be alright.
If you're not planing tons of miles or mountain driving the 545 is *adequate*.
01-17-2018, 07:32 AM
Engine: Dt466e
Rated Cap: 71
I was hoping for higher hp tune with good tranny, otherwise the main bus ive been searching for is a shorter tc2000 (10 window)
01-20-2018, 07:58 AM
Yep and very few stations
