Old 01-16-2018, 10:53 PM   #1
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
which t444e is it
so if i understand right, im reading that there are different HP varients of the t444e. is there a way to tell which one a bus has? i have the vin, no pictures available yet, i have sent requests but bus may not be available yet
vin 1HVBBABN21H407087
one sit says this is engine 7.3L V8 OHV 16V DIESEL/CNG if that helps
jjhwick119 is offline   Reply With Quote
Old 01-16-2018, 11:10 PM   #2
Chassis: Saf-T-Liner MVP ER
You'll have to contact an International dealer with the VIN# to get more info.
The Gates VIN Decoder doesn't mention CNG.
Steve Bracken
Build Thread
Old 01-17-2018, 12:02 AM   #3
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
Are you sure you want CNG? It's either diesel or CNG, not both.
Old 01-17-2018, 07:08 AM   #4
Auction listings very OFTEN say Diesel/CNG.
Roll Your Own Build Thread
Old 01-17-2018, 07:25 AM   #5
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
The ad and 2 websites I used for vin didn't say cng, one vin decoder did. I'm not sure what it is honestly
Old 01-17-2018, 07:34 AM   #6
On online auctions, they're often listed as diesel/cng as they were available that way. Something to do with folks not knowing much about buses. They're secretaries tasked with describing mechanical things in a listing.
Old 01-17-2018, 07:44 AM   #7
brokedown's Avatar
THere is a tag on the passenger side valve cover that will clearly show which tune it has... But good luck getting an auction seller to look at it!
brokedown is online now   Reply With Quote
Old 01-17-2018, 07:47 AM   #8
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Dealer not auction, so I'm hoping for some luck with more info. Bus showing not available for a month though so we shall see if they even have the info
Old 01-17-2018, 07:50 AM   #9
Googling the VIN, I found a listing for it saying its a diesel.
Old 01-17-2018, 08:12 AM   #10
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Lol. No way to keep postings from people. So I guess cng is a different fuel type? Still learning
