Old 09-27-2012, 04:40 PM   #1
yet more 7.3 idi questions
Hi all. new to the forums. crazy as a loon about getting a bus to haul motorcycles on vacation. I have located a good bus for my needs as far as size, condition, price. a 1991 international Thomas 22 1/2 ft 5 or 6 window bus with a 7.3 idi 5 sp manual and braun lift. only potential down side is the 7.3 idi? I have heard these are not just slow but remarkably so. And fuel mpg is not great. I know the engines are reliable,and mechanical injection is a plus for working on. simplicity. I don't have rear end ratio yet. But from what i have read, ratio is not going to correct fully the issues with these old 7.3s
I do plan on driving this bus everywhere i can, cross country, Mexico, Canada etc etc.
Question- first are they really as bad as i have heard, i e cresting hills @ 35. not being able to get out of way of semis going up mountain passes etc etc. yes i know i can put a turbo in it. but for 2500.00 maybe i should look for another bus? Trouble is everything else is perfect. Please lend an opinion, particularly those who have 1st hand experience. I cannot wait to get this project of the ground.
thanks
Bustoff
bustoff is offline   Reply With Quote
Old 09-28-2012, 02:09 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: yet more 7.3 idi questions
You will be going slow, no doubt. You will go slow uphill with a pickup with that engine too. Weight and no turbo is the killer. I would try to find something else that you would be totally happy with. I wouldnt go any smaller than a 5.9 Cummins. That would be the lowest I would go as far as power.
Old 09-28-2012, 04:44 PM   #3
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
all depends on your gearing and how strong the motor is still.
Old 09-28-2012, 05:32 PM   #4
frank-id's Avatar
7.3 or 444cu in can go very fast
Most school buses are not designed to go fast. Spend about $3K and you can go fast. Most engines are very similar and there are no bad engines. Many folks evaluate engines before the experience. I once bought a bus with no working heater, for 2 days at a top speed of 52MPH. With a little money ande a gear change, the bus will go 80MPH.
A bus can be made to an owners wants/needs. Buses used in places with many hills have very low rear axle gears.
Frank............yep, Idaho
Old 09-28-2012, 09:09 PM   #5
Frank- Thanks you seem to be a respected contributor and i appreciate it. I know you can make a bus go fast, however at the loss of power, and at 185 hp and less than 400 ft lbs of torque i am imagining this motor will have a hard time pushing say @ 3.80 ratio. If i was to drive this thing in Florida i can see it. But if i get it to go fast i would doubt i would be able to cross say Eisenhower pass on 1 70 @ over say 20 mph. Correct? You live in Idaho, one of the mountainous states we have.so tell me could you take a 7.3 idi and make it a decent cross country rig? Its a school bus i realize, but after scouring the internet for hrs it seems that the consensus is this motor is one of the worst choices for a cross country vehicle. 70 would be good to be able to do. with cruising around 55- 60 but i really don't want to be going over passes having to pull over for loaded semis to pass. and getting over 10 mpg is what i am after.
thanks again
Bustoff
Old 09-28-2012, 09:22 PM   #6
opus's Avatar
Let me throw this in; I have a 250hp, 8.3 Cummins with a 4.10 rear. I pull big grades at 40-45mph and I pass trucks and RV's. I can pull any grade at that speed. My weight is 25,000. I live in MT and am constantly going up and down.
Old 09-28-2012, 10:14 PM   #7
crazycal's Avatar
What you have is what all buses should have but it's a big difference from an IDI 7.3 engine. That 7.3 is OK in a pickup but I wouldn't want it in my bus.
I'm hungry!
You Gotta Let Me Fly
Old 09-29-2012, 03:13 PM   #8
Opus thanks for that but if i the bus had an 8.3 this thread would not exist. a 7.3 idi is pretty different.
Old 09-29-2012, 05:06 PM   #9
opus's Avatar
You missed my point. You were talking about mountain passes, wondering how you would climb them. I told you how I climb them with a considerably larger engine. So, with that statement, you can be pretty sure that you will be climbing passes pretty dog gone slow, with a non-turbo'd, 7.3 engine.
Old 09-29-2012, 07:04 PM   #10
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
my shuttle with the 7.3 does just fine on highways with 4:10's. i loose speed in the hills but not as much as semi's do etc. only sitting at about 10k lbs though.
in the end its really what the owner wants. if you dont feel a 7.3 is big enough, go bigger. bigger engine isnt necessarily worse. its all about the power to weight ratio.
