Old 02-06-2013, 02:50 PM   #1
Chassis: school bus
Engine: 3208 cat
1989 thomas bus overcharging the batteries
I have a 1989 Thomas flat nose rear engine with a Cat 3208 bus that is over charging the batteries. I have not been able to find any manuels for the bus. I think it is a regulator. Can anyone help? Also there is a red warning light on and a buzzer when you turn the key on
ssengchan is offline   Reply With Quote
Old 02-06-2013, 06:07 PM   #2
GreyEagle's Avatar
Re: 1989 thomas bus overcharging the batteries
The rd light and buzzer could be the low air warning, If it will start, let it run for a while,
if it is the low air warning buzzer and light will go off...... if you drained the air tanks be sure the drain valves are closed for operation.
GreyEagle
Roll - On...
GreyEagle is offline   Reply With Quote
Old 02-06-2013, 11:56 PM   #3
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Make sure your all emergency exits are closed but not locked. That includes roof hatches.
I'm hungry!
You Gotta Let Me Fly
Old 02-07-2013, 08:43 AM   #4
Chassis: school bus
Engine: 3208 cat
Thank you got it started and buzzer went off.
1989 thomas mvp- with CAT 3208 supercon Conversion General Discussions 1 09-12-2010 08:54 PM
1989 Thomas 56 Passenger Bus eugene1617 Conversion Tutorials and How-to's 2 11-03-2009 04:38 PM
1989 Thomas Saf-T-Liner GoneCamping Classifieds | Buy, Sell, Swap 0 01-09-2009 09:05 PM
"Seeker" - 1989 Thomas Pusher - www.vonslatt.com vonslatt Skoolie Conversion Projects 46 05-22-2006 07:14 PM
1989 Thomas Saf-T-Liner vonslatt Skoolie Conversion Projects 49 10-25-2005 09:02 PM
