Old 01-22-2017, 04:34 PM   #1
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
3126b Exhaust Brake
Hey all,
Has anyone ever added an exhaust brake to this driveline, or have a bus that already has one? After using a RAM 2500 with a Cummins and exhaust brake to tow a car 2500 miles, I am sold on exhaust brakes, and wondering how hard it would be to retrofit one. I found a used one that is compatible with my engine:
JACOBS EXHAUST BRAKE DIESEL ENGINE TURBO PART# 025820 MODEL TM3126B CATERPILLAR | eBay
And some documentation on a unit that is similar (but not the same):
http://www.jacobsvehiclesystems.com/...fs/019747F.pdf
Looks like with the Allison trans I have it would require some additional wiring and programming, which I could do, but out here in the rockies it would definitely not be a bad idea! I will do some more research to see if it is feasible, but if anyone has any insight it would be much appreciated.
Thanks!
porkchopsandwiches is offline   Reply With Quote
Old 08-25-2018, 04:55 PM   #2
Coachwork: Thomas I think...
Engine: CAT 3126
Send a message via Yahoo to BUSfan29 Send a message via Skype™ to BUSfan29
did you ever figure out anything with this, i'm sort of curious also..
BUSfan29 is offline   Reply With Quote
