Old 02-16-2016, 06:06 PM   #1
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
C7 Hard Start
Where I was parked gave me the old heave-ho and asked that
a. I pay $25 per DAY
or
b. Find another parking space.
Option B
But, I hadn't started the old girl in about a month, so, quite naturally, she didn't want to cooperate. I made sure that I had plenty of go-juice and, prepared for the eventuality that I would need it, had a brand new can of starting juice.
It took 30 minutes to get her going and I used the ENTIRE can of ether.
I'm thinking that the fuel filter and water separator need replacement. What say?
Old 02-16-2016, 06:31 PM   #2
I'd definitely try that. How much fuel is in the tank?
Old 02-16-2016, 06:36 PM   #3
Jolly Roger's Avatar
Engine: Detroit 8.2
Go easy on the ether!! Your injection system will get addicted to it worse than a drug addict.
Something that I was taught over the years as a heavy equipment operator was to use gasoline on the filter or a spray bottle instead of ether. Gets the same result without the hard knock's and burning up the piston and valves.
The only next thing I would suggest is checking the glow plug wiring and automatic switch. Stay away from ether if you can and check your glow plugs and wiring?
One of my best excavater s had a problem starting after setting and it was because of a broken glow plug wire in the frame somewhere and short term we ran a new hot wire from the battery to the bar that connected all the plugs (on a 4 cyl in this situation ) wire nutted it and used it as needed? It took two people to start it when needed to touch the hot wire to the bar while cranking but it was temporary and worked at the time.
Because it was what it was and in a completely screwed location and the repair bill would be crazy plus downtime we added a toggle switch and connected directly to the glow bar that way the operator/driver didn't need help.
Old 02-16-2016, 06:41 PM   #4
Engine: Detroit 8.2
Sorry forgot to add that I am not a diesel mechanic by trade but I am usually the one thats there to help when it breaks. My ideas are just suggestions to think about are look at?
Old 02-17-2016, 11:38 AM   #5
Chassis: International 1753
Engine: 6.9 International
How cold is it there? When was the last time you filled up? and did you have the block heater plugged in?
Old 02-17-2016, 12:32 PM   #6
Depending upon how cold it was outside the hard starting doesn't surprise me.
Most medium and heavy duty diesel engines do not have any sort of pre-heating provisions for cold starts like glow plugs. When it gets cold out most people plug in their bigger diesels to make them easier to start.
What is more critical than anything else, particularly with newer electronically controlled engines, is you have to have batteries with lots of juice in them. Not only do you have to get the starter to turn a complete turn at a speed fast enough to alert the crank sensor but you have to have enough juice to wake up the computer and tell the pump to turn on and activate the injectors.
I would go easy on the ether. It can break the top rings if you are not careful.
Old 02-17-2016, 12:35 PM   #7
Chassis: Blue Bird
Engine: ISC 8.3
Well done! I did the same thing for a friend's Bobcat skid loader last year. I needed to test for leaks after replacing a hydraulic hose late in the fall but it was such a bear to start and battery was in poor condition it would run the battery dead cranking. I figured out the glow plugs weren't getting power when the switch was pushed, so used a jumper wire to heat them up 10 seconds or so and then climbed into the cab and turned the key. I think he still does it that way; he never did bring it back for a proper fix.
The cold start aid seems like a good place to begin. Some engines just don't have one, but at least go looking and verify operation if you find glow plugs or grid heater.
I don't know about the filter being a problem -- did you have any trouble with low engine power when it was run last? When you did finally get it started, did it run fine? I'd think if a filter were causing a starting problem it would also cause running problems.
I'm not familiar with your injection system. Does it have some kind of electric lift pump? Is it working? My ISC (as an entirely unrelated anecdotal example) runs a lift pump only in the beginning; the injection pump is designed to pull fuel all the way from the tank once the engine is running.
Old 02-17-2016, 03:58 PM   #8
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Block heater/cold start cord has a missing prong. I've got the new cord, but I can't get under the bus in order to replace it due to my infirmities.
Plenty of fuel on board and new, as well. The temps have been dipping down into the high 30s/low 40s at night lately.
Engine turns very nicely.
Addendum -- I have to move AGAIN because the owner of the property is bringing in some earth movers in the morning. Can't I get a break? I can't possibly move the bus and my Suburban at the same time. I have to limit the distances to hobbling distances because I'm permanently on crutches.
Old 02-17-2016, 06:05 PM   #9
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Just checked the pricing for fuel filter ($21.99) and water separator ($48.49). No telling how much water is in that separator.
Old 02-18-2016, 10:31 AM   #10
Alright, just making sure you're burning winter fuel instead of summer. If you're thinking that it is turning over fast enough then the block heater isn't necessary. Every C7 I've seen had a grid heater in the intake manifold cover. Even the ones that came from florida, so I'm not sure if it was optional. Their should be two studs on top for the heater, one being power and the other grounded to the manifold. It should be obvious which one is which, so check if you have 12v to it when keyed on.
My guess is that yours is not working. Especially since you used ether on it and it didn't explode in the manifold. Those grids will get cherry hot if you leave them powered on long enough.
If you've never replaced the filters, then I would do it. They're a cheap checkmark on the list of things to cause a no start. But I doubt that the fuel filters are the cause. Just make sure that you prime the new filters.
