Old 06-27-2013, 11:03 PM   #1
bus-bro's Avatar
Engine: 3208 na boat anchor
Cat 3116 White Smoke
I know of someone whose bus started putting out a cloud of white smoke while travelling through the middle of nowhere. The experts, reached by cellphone, believe this to be an injector issue. Does anyone know the problems with Cat 3116's, and specifically with replacing injectors?
Old 08-10-2013, 09:44 PM   #2
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
Re: Cat 3116 White Smoke
White smoke is an indicator of sucking air into a fuel line/ system, among other things. My V8 3208 did this; the throttle rod seals were bad and letting air into the fuel system. Other symptoms were lack of power, inability to maintain proper idle, surging. Could also be bad rings? Good luck!
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
Old 08-11-2013, 06:55 AM   #3
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Not likely, bad oil control rings burns blue.
Old 08-11-2013, 03:00 PM   #4
bus-bro's Avatar
It was a bad injector dumping fuel into one of the cylinders, which was found to have a failed exhaust valve in that bore also. Engine is toast, so to speak. Injectors were priced at $300 each ($1800 for 6).
cat 3116 a good idea natertots Conversion General Discussions 11 08-25-2014 01:59 PM
co2/smoke alarm timbuk Conversion General Discussions 3 01-18-2011 03:19 PM
3116 vs. 3208? Locutus Caterpillar Drivetrain 1 05-13-2010 08:39 AM
The color of smoke? TygerCub Mechanical and Drivetrains 2 03-29-2010 10:47 PM
Woodstove in my bus leaks smoke. arfisher83 Conversion General Discussions 12 01-28-2008 09:14 PM
