Old 01-02-2013, 10:00 PM   #1
Chassis: Frieghtliner
Cat 3126 governor
Does anybody know how to get rid of the governor on a Cat 3126 engine. The bus seems to not have enough power, and it tops out at 55-60 mph. I talked to a bus driver, and he said that they have governors on them.
Gearhead94 is offline   Reply With Quote
Old 01-03-2013, 10:41 AM   #2
opus's Avatar
Chassis: All-American R/E
Re: Cat 3126 governor
You should be looking more at your rpm's and rear gear ratio. Where are the rpm's when it tops out?
Old 01-11-2013, 08:40 PM   #3
I have no idea what the RPMs are, my dad drove it home cause he has a CDL A. He said he had it to the floor, and it topped out at like 55 mph. Is there anyway to make it go any faster. I would like to go at least 65, to go the speed limit on the interstate. I thought about changing the rear gear ratio, but thats expensive and time consuming.
Old 01-11-2013, 08:52 PM   #4
opus's Avatar
A wild guess, the answer is no. Its more than likely governing out at its specified rpm, which is what you want. I cant suggest anything until you find out what rpm its turning at top speed...sorry.
Old 01-11-2013, 10:26 PM   #5
frank-id's Avatar
Re: Cat 3126
The Cat 3126 engine is not a very powerful engine and does not make high horsepower. The govenor is to control engine operating conditions to about 2250 RPM. The top speed is determined by the rear axle gears. The higher the ratio, the lower the top speed. To determine the rear axle ratio, raise one side of the bus so the wheel may be turned. The park brake needs to be released so the wheel can be turned. With a chalk or marker, place a mark on the raised wheel pointing at the earth under wheel. Make another mark on the driveline about 6 inches long near the rear ujoint, horizonal. Turn the raised wheel slowly while watching the driveline mark. When the wheel makes a single revolution, the driveline turns should be remembered.
Many buses and trucks have a 5:1 gear ratio. A good ratio for hiways is 3:73 down to 4:10. Most rear gears can be changed to satisfy any application.... Frank
Old 01-11-2013, 10:51 PM   #6
How much would it cost to change the rear end ratio. I know that it wont be cheep. Also would it be possible to do it on my own, or should i take it somewhere to have it done. Would a programer such as this one from TS performance be a good upgrade? http://www.tsperformance.com/MPHD_tuck.html
Old 01-12-2013, 08:53 AM   #7
superdad's Avatar
Chassis: MVP
The 3126 is an electronically controlled engine. It can have a vehicle speed governor programmed into it. The only way to know for sure is to take it to a Cat service center and have them hook it to a computer and look.
Superdad
Conversion thread.
superdad is offline   Reply With Quote
Old 01-13-2013, 06:53 PM   #8
Coachwork: Ward Genesis
Engine: DT466/MT643
Re: Cat 3126
I have seen 7.2 Cats running 330HP in RV's and 275 in trucks. The one I drive every day is 250HP, power peak is 2200, governor is 2600. A 7.2 Cat with no OD trans and fullsized 22.5" truck tires wants a 4.11 axle gear...maybe 4.30's if it's really low-power.
Jarlaxle
Old 01-15-2013, 04:41 AM   #9
agree with last post.
axle or pot should be changed out is my guess as many of the newer ones are geared to go no more than 60 mph. If bus is a pusher, conventional axle can be installed if flipped and plug holes changed...
My 3208 Cat is underpowered in the rocky mountains, esp when full of car parts and towing box trailer with same...
Old 02-20-2013, 08:10 PM   #10
Year: 1974
Engine: Detroit Diesel 6-71
I spoke to the head maintenance guy at the nc school bus supply today, and state law in nc is that all school buses be governed at 45mph. He said to bypass this take it to CAT to be reprogrammed as stated above. I'd lose my mind going 45 everywhere lol
Proud new owners of a 1974 Crown Supercoach - the big rolling twinkie!
viewtopic.php?f=9&t=466562
inkblots84 is offline   Reply With Quote
3126 in frame overhaul rhickman Caterpillar Drivetrain 18 03-05-2016 05:28 PM
T444E vs. Cat 3126 M1031 Mechanical and Drivetrains 5 04-18-2014 08:26 AM
8.2 detroit governor levi Conversion General Discussions 5 02-13-2013 07:52 PM
8.3 vs 3126?? huff0026 Mechanical and Drivetrains 8 06-30-2012 08:29 AM
Governor adjustment reprobate Conversion Tutorials and How-to's 6 12-29-2007 06:56 PM
