02-16-2018, 02:15 PM
Cat 3126 Thomas trans question
Does anyone know what trans fluid and how much is needed for a 1999 Thomas, 37' 10" bus? It sat from end of July until now. Pulled the dipstick and it's not even registering. I don't know what kind of trans other than it's an automatic.
Any help is greatly appreciated.
02-16-2018, 02:48 PM
Chassis: Saf-T-Liner MVP ER
The normal check is wih the transmission fluid at operating temp, and the engine idling.
Which transmission?
02-16-2018, 03:05 PM
There should be a tag on the passenger side of the transmission that will tell you what model of transmission you have. It may be covered with stuff so take a rag the first time under.
Robin
Nobody's Business
02-16-2018, 03:32 PM
Chassis: Thomas
Engine: CAT 3126
Likely a 3060 like mine.
02-16-2018, 05:15 PM
It's an Allison MD3060. It's warming up now. Worst case scenario, what's the capacity of it if it all drained out?
I'm getting to old to crawl around on the cold ground like that! LOL The identification plate was on the driver's side. But at least I know where to find it now, thank you!
Kudos to y'all for such a quick response! Wow!
02-16-2018, 05:26 PM
Chassis: Thomas
Engine: CAT 3126
Let us know! I haven’t changed my fluid because the maintenance log showed it still being good for a while. I should probably look into it before my big trip though.
02-16-2018, 05:31 PM
Engine: 3126 CAT/AT545
Rated Cap: 26
hey guys, just saying hi and seeing if I can post. just got my bus a couple days ago...starting the teardown...
02-16-2018, 05:58 PM
Welcom
It works. You won't be able to post links until you have posted something like 5 or 10 times. Other than that, you're good.
Robin
Nobody's Business
02-16-2018, 06:13 PM
Thanks again y'all! Got her moving. It'll be a miracle if she makes it this 600+ mile trip, wish me luck!
02-16-2018, 06:27 PM
If you get a bus running it will usually do fine as long as you want to keep driving it. Problems come at startup, so don't shut her down till you get home.
Remember, drive it like you stole it. Buses are invisible.
Robin
Nobody's Business
02-16-2018, 07:19 PM
Rated Cap: 26
"buses are invisible"
i agree, unfortunately, i had to run mine home without reg or insurance. never got a look. took it easy and safe. i was leaving like 200 feet between me and anyone in front of me haha
02-16-2018, 07:42 PM
That's the ticket. It also helps if you have an old man hat. It makes a good profile of you when the cops are passing.
Our temp tags are supposed to be mounted on the inside of the rear window on the driver's side. Unfortunately the tag does not show through the tinted window at all, and bear in mind that you can get a ticket for an improperly mounted temp tag. By law it was in the right place. I drove around for several weeks before I received plates and never got so much as a long look. After you paint the bus it becomes visible and you're automatically classified as a bus driving hippy. Make it easy on yourself and just slip into some tie-dye clothing.
Robin
Nobody's Business
02-16-2018, 09:18 PM
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
The local radio stations around here are raising quite an uproar around here over the quantity of vehicles running the metro St.Louis area on temp tags having folks send them phone photos there are dozens of them many a year or two expired.
02-17-2018, 06:29 AM
Thanks! This trip then just a short one at less than 10 miles and she can RIP lol
I'm not even shutting her down at fuel stops.
02-23-2018, 08:25 AM
Turns out the trans is just fine. It's not an issue of, it dumped the oil. 2 gallons in under 13 miles.
I made it from a rest area to a teeny, tiny truck stop in that short trip. As I backed in to par, the power steering line blew (2nd time for that).
Is there anyone near Orangeburg/Columbia, SC that maybe willing to give me a hand? Please?
02-23-2018, 10:23 AM
Chassis: Thomas
Engine: CAT 3126
Ouch. Sorry. Any idea where it is leaking from? As I imagine you know the cat 3126 is sensitive to oil cleanliness and volume. Don’t want to blow up the HUEI pump.
02-23-2018, 10:35 AM
I've been under twice and can't find it. Everything is wet with oil. I only know the puddle is pretty close to the bumper.
With the amount of oil that's blown out of her, it' was all new at this point lol 6 plus gallons in under 400 miles.
02-23-2018, 11:20 AM
Chassis: Thomas
Engine: CAT 3126
Pictures? Front main seal?
04-11-2018, 04:06 PM
The leak turned out to be just a bolt that keeps vibrating loose.
I'm now dealing with that same tranny issue that's got to be a loose connection somewhere.
I keep hearing an electrical clicking sound in the instrument panel. The gear indicator lights flicker. It goes from neutral to a zero to nothing and randomly cycles thru. I'm not sure what it is, but I need to make another 61 mile trip and now it's acting as if I'm not turning the key.
I almost can't wait to not have this beast anymore...
