Old 07-27-2018, 06:44 PM   #1
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
Fuel tank size
We have a 2004 Thomas 40’ front engine flat nose with CAT 3126 and MD3060 transmission
I believe the gas tank is 100 gallons? But we’ve never filled it up.
We’re leaving on a 2100 mile trip and will be filling it up for the first time and curious if that sounds right that we probably have a 100 gallon tank?
If so how much actual fuel is feasible to squeeze into it? 90? 85?
Thanks in advance
Mgulley82 is offline   Reply With Quote
Old 07-27-2018, 07:10 PM   #2
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Mine is an RE CAT 3126 3060 13 window. It has 100 gallon tank. If it were empty I’m guessing you could fit a full 100 in, but I usually fill when it will take about 60 gallons - in my case somewhere around 500 miles from last fill up.
My Build Thread:
https://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 07-27-2018, 07:10 PM   #3
Huskerbus's Avatar
Rated Cap: 31 w/4 wheel chair spots
If the tank is accessible from underneath, you could measure it’s height, width and depth and do some math?
Huskerbus is offline   Reply With Quote
Old 07-27-2018, 07:21 PM   #4
Mgulley82's Avatar
Man why didn’t I think of that?!?!?
Old 07-27-2018, 08:07 PM   #5
No matter how many gallons you find it takes, don't fill it right up. The fuel foams and needs expansion space so if you have 100 gallons maybe 85-90.
And don't let it get so low that the fuel can't get picked up and pumped.
Bleeding is no fun as many have had to do.
Old 07-27-2018, 09:50 PM   #6
Your Cat will get awful indigestion if you try and fill it with gas. . . .
Like BlackJohn said, watch out for foaming when filling diesel. The fuel foams in the filler pipe (like a root beer float), and sometimes it will fill the pipe. (Ford pickups from 2000-2006ish often have this problem.) Sometimes the fuel pump nozzle detects the foam, thinks the tank is full, and shuts off. So don't over-fill the tank, but if you know it was down to a quarter, and it only takes 6 or 10 gallons, you've probably got a foam problem. Wait a few minutes, and slow down your fill speed on the pump a bit.
Old 07-27-2018, 10:01 PM   #7
My Genesis has a 60 gallon tank and the fill spout is mounted at such an angle to prevent "filling" the tank. When it starts coming out the spout there is still 3-4" of airspace in the tank. If I send the flip bus to salvage I have to siphon more than 3/4 of a tank.
Old 07-28-2018, 10:41 AM   #8
Perhaps you could email or call Thomas and get a copy of the build sheet for your bus?
That would tell you a lot about your bus including the fuel tank info.
