Old 05-19-2010, 09:28 PM   #1
frank-id's Avatar
Information about the Cat 3208
http://www.enginebuildermag.com/Article ... iesel.aspx
Old 05-19-2010, 09:59 PM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
Re: Information about the Cat 3208
So, there is hope for the 3208 afterall. He reccomends a turbo's 3-ring piston for the 3208NA. Does anyone know if this was done to the REMAN(ufactured) engines?
Old 06-18-2010, 08:49 PM   #3
bus-bro's Avatar
did they get new sleeves?
Old 06-19-2010, 12:03 PM   #4
frank-id's Avatar
Re: Information Cat 3208
Every engine rebuilder has a different process in any engine rebuild. Engine piston sleeves are available for about any engine. The "Kitty" 3208 has no removable sleeves but sleeves can be fitted to the block. Rebuilding and diesel engine is very expensive and I mostly look for a used engine. There are lots of reasonable priced used engines on the market place. Most bus do not use turbo engines that can be found at some truck salvage place.If an engine is needed,
do lots of looking and inquiring. Frank
Old 07-17-2010, 10:21 AM   #5
Chassis: Ford B700
Engine: 5.9L Cummins
Rebuilt sleeved parent bore engines are typically not highly desired. It isn't the same as a wet sleeved factory engine.
The 3208 will die a slow death and become more and more rare. Even the 2 stroke DDs are being seen less and less and they were meant to be overhauled indefinately for the most part.
You see the 3208s in alot of boats but when many repower they upgrade to a more powerful and efficient engine like the Yanmars for not alot more money. They just weren't meant to be around forever.
kamoo is offline   Reply With Quote
Anyone need a 3208? opus Classifieds | Buy, Sell, Swap 0 11-11-2010 09:36 PM
cat 3208 houskou Conversion General Discussions 3 07-30-2010 07:22 AM
3116 vs. 3208? Locutus Caterpillar Drivetrain 1 05-13-2010 08:39 AM
Cat 3208 coolant drain? paul iossi Caterpillar Drivetrain 2 11-11-2009 12:32 AM
Need help with Diesel information and towing information phillip266 Everything Else | General Skoolie Discussions 3 12-20-2004 07:33 AM
