Old 09-11-2019, 12:38 AM   #21
I bought one of these and uses HVAC tape to tape sensors to metal inlet and outlet of radiators, A/C coils and the like for various testing... you can get sensors with longer wires..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
That looks like an excellent diagnostic tool. It has quite a range of temperatures it can measure! However, at $158.00 I will have to wait untill I can afford to make such a purchase. Thank you VERY much for the link and the fine tool idea.
Old 09-15-2019, 03:39 AM   #22
I have been reading through a very good document from CAT called "Know your Cooling System":
CAT KnowYourCoolingSystem.pdf
They indicate that by monitoring 6 points in the cooling system, the problem can be determined:
1. Radiator top tank
2. Radiator bottom tank or water pump inlet
3. Water pump outlet or oil cooler inlet
4. Water temperature regulator housing
5. Torque converter oil outlet
6. Engine oil manifold or oil cooler outlet
So two of those nice temperature monitors would be handy. I am not yet done reading the document, but perhaps it can shed more light on the subject for me.
Old 09-15-2019, 06:32 AM   #23
ive always measured trans temp in the pan.. but measuring fluid temp going into and out of the cooling loops to the radiator would be a good indication of how much loadthe trans puts on the cooling system..
radiator inlet and outlet are also good as they let you know if your radiator and fan are actually doing anything.. ie is there a temp drop across the coils?
as for my temp logger.. sure i can (and will) build something much cheaper, however I do a lot of stuff with A/C.. both in my own and helping people get their Home and car / Bus A/C working , installed, etc.. so measuring temperatures easily is important.. plus im admittedly a tool-geek. so if I can put a tool in my tool-box that I'll use more than once I'll likely do it.. lol
Old 09-15-2019, 08:49 AM   #24
International cluster freeze is a easy fix. Go to YouTube and see how the guru fixed it. International cluster freeze google itCheers
Dirtdoctor is offline   Reply With Quote
Old 09-16-2019, 01:28 AM   #25
I learned today that a temperature difference of 6 to 9 degrees (F) between the top tank of the radiator and the bottom tank is a healthy radiator. I'll be flushing the coolant system tomorrow and will take IR gun measurements of the top and bottom tanks.
I'd love to see your home brewed temperature logger when you have made it.
Old 09-16-2019, 09:39 AM   #26
Chassis: International 1753
Engine: 6.9 International
Attachment 37541
Now you're on to something. That is a pretty good article.
Old 09-16-2019, 09:41 AM   #27
For what it’s worth- I run four international trucks in a fleet. One truck got a newer engine with more beans for hp. It’s been overheating and after spending time on a racing engine forum tracing radiator issues I have discovered the simplest fix!Airflow- The fan blows plenty of air but the hood vents are t large enough to
Let the hot air pass out and away from the engine. So a McGyver fix was to open the hood an additional 3/4” to let the volume of air out. I will be enlarging the tiny vents in the fiberglass hood and adding two or three 2” holes to the left and right fender well. So open that hood and see if that makes any changes.
Cheers
Old 09-16-2019, 10:23 AM   #28
Umm, on most trucks your hot radiator air will pass through the engine compartment and exit toward the ground and wheel wells, not out the hood.
Old 09-16-2019, 02:37 PM   #29
Well, check the edge of the hood - my 275hp and 330hp unit’s have vent holes along the edge. I’ll snapA photo and show ya later. But I’ve been hauling heavy 38,000 payloads up to a job site, When I opened the hood to Let More air evacuate the engine compartment the temp
Dropped quickly and the next 10 deliveries to the same site the engine didn’t overheat.
Cheers
Old 09-17-2019, 02:17 AM   #30
Thank you for the replies!
In this FS-65, the fan blows the air down under the engine, even with the hood open. I was a bit surprised the first time I noticed this. Some air does go over the engine and to other parts of the compartment, but the volume moves down.
