Old 06-28-2019, 04:19 AM   #1
Maintenance Tip: CAT 3126 Water Pump Belt Replacement
Yesterday, I went to replace the water pump V-belt (cogged) on our CAT 3126. I had removed the idler pully for the serpentine belt and loosened up the serpentine tensioner so that I could remove the water pump V-belt. I found that the darn belt would NOT fit around the harmonic dampener.
I was looking at having to remove the harmonic dampener! I was thinking this was a crazy design that required removing the harmonic dampener for a simple belt change!
I went back into the house to vent a little and literally cool down (hot day outside) and told my wife about it. She is my internet research assistant and in a few minutes she had the solution ... turn the belt inside out so that the cogs of the V-belt point outward! This provides an additional 1/2" in diameter to the belt.
I went back out to give it a try ... sure thing, it was enough to allow the belt to slip over the harmonic dampener.
Old 06-28-2019, 05:42 AM   #2
HazMatt's Avatar
Chassis: IH 3800, 8 window
Wierd!
But, if ya gotta go backwards to move forward, so be it.
Cha-cha-cha!
Old 08-25-2019, 11:50 PM   #3
Appreciate learning that on the front end -- looks like my bus is a twin to yours.
Old 08-26-2019, 03:56 AM   #4
Indeed, it does!
