Old 07-21-2018, 12:27 PM   #1
Mgulley82's Avatar
Chassis: 40' Saf-T-Liner MVP ER
Engine: CAT 3126 7.2L
Power steering fluid
I have a 2004 Thomas MPV CAT 3126 with power steering pump mounted to back of air compressor
I fixed some power steering leaks and am now ready to fill the system but noticed the power steering fluid is not red like I drained out
Iím assuming it had ATF fluid in it?
Can I use the power steering fluid i already bought instead?
Mgulley82 is offline   Reply With Quote
Old 07-21-2018, 12:37 PM   #2
Tryonis's Avatar
Chassis: TC2000 RE
Mine just uses regular old 10w30 motor oil.
Build Thread:> https://www.skoolie.net/forums/f11/1...yet-22358.html
Tryonis is offline   Reply With Quote
Old 07-21-2018, 03:56 PM   #3
mine uses auto trans fluid... dexron III
I have that in both my busses
Old 12-25-2018, 12:39 PM   #4
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
Mgulley82 -》 is it a high pressure line off the pump to a steel line to the front? Something blow and I am trying to figure old what to do.
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
