Originally Posted by brokedown
Drive another hundred miles today without issue. Looks like the fuel filters solved it, so I'll be picking up another set next week. I also need to check/replaced my air filter and look into getting my fuel tank cleaned
About those Fuel filters. I'm just seeing the pics posted. Maybe i'm wrong but it almost looked like red alge more than rust. In person was it really rust??
I'd buy Several filters, after all they don't go bad. On the road you can fill one with any New motor oil when installing.
If so Immediately go to the drain plug on the tank and crack it loose and see what leaks out first. Fuel?? Water??
When mine is parked it is parked on Full tanks. This keeps the air in the tanks to a absolute minimum.
I've got the same 12V 5.9 in My 94 Ford. My rear filter has a drain plug on it. Every spring on first startup I crack that plug loose (with the engine running,
to see IF there is ANY water in the filter.
