Old 06-17-2011, 10:25 AM   #1
opus's Avatar
Chassis: All-American R/E
Re: 220 NHH Glow Plug in intake?
That could be, I rather doubt it. I dont ever recall a 220 having one...its been a while though. I would expect a compression release to be found for sure.
Old 06-17-2011, 12:18 PM   #2
frank-id's Avatar
Cummins.... NHH Glow Plug
Yep, the Crown Cummins did use a single glow plug. Cummins have always been a bit fussy starting at cold temps. The wiring is missing from your bus and almost all others. Usually there is a transformer located near the small electrical panel near the engine under the drivers window. That panel usually has a switch labeled glow plug. The sequence is at drivers seat, engine ignition on, outside to side compartment, hold glow plug switch for a 10 or so count, then push start switch while holding/opening throttle. This start method was marginally effective. When the temps plunge here in Idaho, I use that glow plug port to squirt in some start fluid as engine is turning. Starts great even at -22 degrees. My remote start switch is wired to spin engine merely by pushing the outside button.
At the same panel, there is also a small pump for adding fuel when a start is attempted. Starting fluid or a gas laden rag does a better start job. Frank
Old 06-17-2011, 10:55 PM   #3
opus's Avatar
Starting fluid is fine...IF you know how to use it properly. Of course, not with a glow plug or manifold heater.
Old 06-18-2011, 12:25 PM   #4
opus's Avatar
Not from where I am sitting.
Old 07-19-2012, 11:17 PM   #5
Year: 1969
Chassis: crown
Engine: 743 Cummins
Rated Cap: 75
my crown has most of this still-- there is a pump plunger ,a push button and a big red light ... as I understand it - you push the button, the light glows, after a time you pump the 'handle in and out to spray fuel onto the white hot glowplug coil, it burns and heats the intake manifold and air . basicly , you start a fire in the intake ........ crank while doing all the above .... motor may start ... got this from some oldtimers at the historic truck site .. and like I said all this stuff is still on mine .. looking in the parts books reveals that on most 743 cummins engines the comp ratio is down around 13-15 to 1 ... not high by today's diesel specs ..
moosiah is offline   Reply With Quote
Old 07-28-2012, 08:52 AM   #6
Coachwork: Ward Genesis
Engine: DT466/MT643
Note: Liquid Wrench is a whole lot easier on the rings than ether. Since WD40 was reformulated a few years ago, it doesn't work well as starting fluid anymore.
Jarlaxle
Old 08-02-2012, 01:43 AM   #7
Year: 1969
Chassis: crown
Engine: 743 Cummins
Rated Cap: 75
when starting mine up from dead cold, I do it the way my dad did it on the 190 in our hay truck : hold the compression release lever down, start button, spin the engine until it starts to spin up- you can hear it speed up slightly, then drop the compression lever---- brumm-- running .. Once it's warm - then I just hit the start button inside , hardly cranks , and it's off... I use 3 grp 31 batts in parallel, got rid of the 2 giant 8d's it came with..
Old 08-02-2012, 10:28 AM   #8
What does Liquid Wrench do to the air filter element?
Rich
you spray the starting fluid, etc after the air filter.. or in manifold port..
Old 08-02-2012, 12:44 PM   #9
TheRainbowBoxer's Avatar
Engine: 5.9 Cummins 12v
Rated Cap: 78 Passenger
Interesting aside on all of this hard starting talk...
My buddy, Stretch, has an M35 deuce and a half military truck with a multi-fuel engine. He is running straight used motor oil as fuel, which makes the truck naturally harder starting. Once, when it was cold out and he had misplaced his starting fluid, he had me plug the end of the exhaust stack (while he cranked) to force the compression, hence heat, to build up. Never would have guessed something like that would work, but it did.
-Dan
"What's the matter Col Sanders? Chicken?" -Dark Helmet
lu·di·crous [loo-di-kruhs]
adjective
causing laughter because of absurdity; provoking or deserving derision; ridiculous; laughable
viewtopic.php?f=9&t=11840
TheRainbowBoxer is offline   Reply With Quote
Old 08-03-2012, 08:06 AM   #10
Year: 1987
Coachwork: ward
Chassis: international
Engine: 9.0
I have multiple ways of helping a diesel start. But, the ones I have are 22-1 compression, and start at 10 degrees without any help, if you are running diesel fuel in them.
That being said, I run straight motor oil as fuel. (M35 military truck with multifuel engine)It's a lot harder to start. It will start above 70 degrees or so. Used gasoline in a spray bottle to help, ether, or plugged the exhaust.
Truck comes with a spark plug and a sprayer, you push a button while starting, and it makes a flame in the intake to help it start. I have no idea how well it works, due to running oil in the tank. On diesel it probably works fine.
I bought a ether start kit to install, haven't done it yet. You pull a cable or push a button, and it gives the engine a measured shot of ether to start. Uses a bottle that looks like a propane bottle. Supposedly you get 200 starts out of a bottle. Google quickstart.
Stretch is offline   Reply With Quote
Air Intake Scoop Stu & Filo. T Conversion General Discussions 5 12-07-2014 06:35 PM
Simple way to plug in? Kathy WI Electrical, Charging and Solar 17 07-17-2013 12:13 AM
Fresh Air Intake Alex and Angie Conversion General Discussions 3 06-11-2012 12:52 PM
Why are there no glow plugs? Diesel Dan International | Navistar Drivetrain 4 02-16-2011 12:40 PM
mystery plug? The Wanderer Conversion General Discussions 5 04-30-2007 01:20 PM
